  • saji 83 posts 38 karma points
    Nov 18, 2009 @ 10:16
    saji
    How can i pass dynamic values to .netusercontrol values.
    Hi all,
    i have a macro developed in .net to which i need to have the page id passed dynamically.
    How it can be done. Now I can pass the parameter to the marco and is working fine.
    but i want to pass the value dynamically. Is it possible to do that in XSLT?
    Or how can i trigger the usercontrol macro dynamically with different parameters?
    Thanks.
    Nov 19, 2009 @ 09:41
    Ismail Mayat
    Saji,
    If the property to pass in is the current page then you can do [#pageID] see here for more information about passing parameters into a macro.
    Regards
    Ismail
    Nov 22, 2009 @ 11:41
    saji
    Hi Ismail,
    Thanks for your reply.
    But that is not my issue. what i want is to call the usercontrol in xslt.
    In xslt i'm looping thru some nodes and i have to show details in user control depending on each node.
    Thanks.
    Nov 22, 2009 @ 11:54
    Why would you want to pass the results to a user control?
