I'm having some trouble with XSLT in trying of generating af nested navigation. I receive following XSLT error just before the xsl:for-each in the RenderSubNavigation template:
System.Xml.Xsl.XslTransformException: Attribute and namespace nodes
cannot be added to the parent element after a text, comment, pi, or
sub-element node has already been added.
Hi , my xslt also give error (Attribute and namespace nodes cannot be added to the parent element after a text, comment, pi, or sub-element node has already been added.) on bold syntax given below, please help
XSLT trouble with nested navigation
System.Xml.Xsl.XslTransformException: Attribute and namespace nodes cannot be added to the parent element after a text, comment, pi, or sub-element node has already been added.
XSLT code:
<!-- XSLT variables -->
<xsl:variable name="level" select="1"/>
<xsl:template match="/">
<!-- Building two-level UL list of navigation nodes -->
<ul class="sf-menu-x">
<li><a href="/" title="Forsiden">Forsiden</a></li>
<xsl:for-each select="$currentPage/ancestor-or-self::node [@level = $level]/node [string(data [@alias='pNaviHide']) != '1']">
<li>
<xsl:if test="$currentPage/ancestor-or-self::node/@id = current()/@id">
<xsl:attribute name="class">current</xsl:attribute>
</xsl:if>
<a href="{umbraco.library:NiceUrl(@id)}" title="Gå til {@nodeName}">
</a>
<xsl:call-template name="RenderSubNavigation">
<xsl:with-param name="parent" select="."/>
</xsl:call-template>
</li>
</xsl:for-each>
</ul>
</xsl:template>
<xsl:template name="RenderSubNavigation">
<xsl:param name="parent" />
<!-- Build the second-level navigation list, if the parent node contain any childs -->
<xsl:if test="count($parent/child::node [string(data [@alias='pNaviHide']) != '1']) > 0">
<ul>
<!-- ERROR OCCURS HERE -->
<xsl:for-each select="$parent/child::node">
<li>
<xsl:if test="$parent/node/@id = current()/@id">
</xsl:if>
<a href="{umbraco.library:NiceUrl($parent/node/@id)}" title="Gå til {$parent/node/@nodeName}">
<xsl:value-of select="$parent/node/@nodeName"/>
</a>
</li>
</xsl:for-each>
</ul>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
Thanks in advance
/Anders
Problem is solved. It was some error inside the xsl:for-each loop with the xsl:attribute tag
/Anders
Heya Anders,
thanks for kindly posting this XSLT, it helped me create my nested navigation.
later,
Muzi
<xsl:for-each select="Features/ProductName">
<xsl:variable name="FileName">
<xsl:value-of select="@fileName"/>
</xsl:variable>
<td align="center">
<xsl:choose>
<xsl:when test="@fileName!=''">
<xsl:element name="a">
<xsl:attribute name="onclick">OpenCarrierOutline('<xsl:value-of select="$ServerName"/>','<xsl:value-of select="$FileName"/>');</xsl:attribute>
<xsl:attribute name="href">#</xsl:attribute>
<xsl:value-of select="."/>
</xsl:element>
</xsl:when>
</td>
</xsl:for-each>
please help
kapil Gupta
Make sure you don't have a <xsl:preserve-space elements="..." /> in your stylesheet for an "a" element.
Furthermore, you're missing a closing </xsl:choose> right before the </td>.
