The XSLT won't save and the error I get is this???
System.Xml.XmlException: '=' is an unexpected token. The expected token is ';'. Line 24, position 137. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args) at System.Xml.XmlTextReaderImpl.ThrowUnexpectedToken(String expectedToken1, String expectedToken2) at System.Xml.XmlTextReaderImpl.ThrowUnexpectedToken(Int32 pos, String expectedToken1, String expectedToken2) at System.Xml.XmlTextReaderImpl.HandleEntityReference(Boolean isInAttributeValue, EntityExpandType expandType, Int32& charRefEndPos) at System.Xml.XmlTextReaderImpl.ParseAttributeValueSlow(Int32 curPos, Char quoteChar, NodeData attr) at System.Xml.XmlTextReaderImpl.ParseAttributes() at System.Xml.XmlTextReaderImpl.ParseElement() at System.Xml.XmlTextReaderImpl.ParseElementContent() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.Xsl.Xslt.XsltInput.ReadNextSiblingHelper() at System.Xml.Xsl.Xslt.XsltInput.ReadNextSibling() at System.Xml.Xsl.Xslt.XsltInput.MoveToNextSibling() at System.Xml.Xsl.Xslt.XsltLoader.LoadInstructions(List`1 content, InstructionFlags flags) at System.Xml.Xsl.Xslt.XsltLoader.LoadTemplate(NsDecl stylesheetNsList) at System.Xml.Xsl.Xslt.XsltLoader.LoadRealStylesheet() at System.Xml.Xsl.Xslt.XsltLoader.LoadDocument() at System.Xml.Xsl.Xslt.XsltLoader.LoadStylesheet(XmlReader reader, Boolean include)
Any ideas why its doing this? As I say it saves and works a treat with the BBC URL's??
And There I Was Doing So Well!
I have a little macro that I am reading RSS feeds with using
umbraco.library:GetXmlDocumentByUrl()I have it working using a BBC news RSS feed, but as soon as I change the URL to an eBay RSS feed URL like below
http://rss.api.ebay.com/ws/rssapi?FeedName=SearchResults&dfsp=32&from=R6&nojspr=y&output=RSS20&saaff=afepn&siteId=3&afepn=5336246701&customid=&satitle=vht&fbfmt=1&sabfmts=0&sascs=0&fss=1&saslop=1&sasl=usauto1997&fsop=2&fsoo=2The XSLT won't save and the error I get is this???
System.Xml.XmlException: '=' is an unexpected token. The expected token is ';'. Line 24, position 137.at System.Xml.XmlTextReaderImpl.Throw(Exception e)
I'll take a stab at it...
change all the & to & in the url line... that's why you see it say it expected a semicolon rather than the equal sign.
cheers,
doug.
You are of course... An absolute LEGEND =)
