  • Chad Rosenthal 272 posts 474 karma points
    Dec 03, 2009 @ 23:03
    Chad Rosenthal
    Why is there a method called DateGreaterThanOrEqualToday but not....
    a method called DateLessThanOrEqualToday?
  • Peter Dijksterhuis 1442 posts 1722 karma points
    Dec 04, 2009 @ 08:40
    Peter Dijksterhuis
    If you swap the to dates to the method, you get the same effect.
  • Thomas Höhler 1237 posts 1709 karma points MVP
    Dec 04, 2009 @ 08:41
    Thomas Höhler
    Just add a day and use the negotiation *g*...
    You can easily create this function and use it as an xsltExtension for yourself. Do you need an example?
    Cheers, Thomas
