  • Bas Wensveen 54 posts 75 karma points
    Dec 04, 2009 @ 16:22
    Bas Wensveen
    Passing a parameter xslt does not work
    All,
    Does anyone understand why the code below is not working? Somehow the content picker (pageLinkConsument) content is not passed to my xslt. The content picker does have a value, the otherwise clause is always evaluated no matter the value and Content picker is selected. I'm using  umbraco v 4.0.2.1 (Assembly version: 1.0.3441.17657)
    HTML file
    <a href="<umbraco:Macro Alias='PageNiceUrlForPageId' pageId='[#pageLinkConsument]' runat='server'></umbraco:Macro>" />
    XSLT file
       <xsl:template match="/">
          <xsl:variable name="pId" select="string(/macro/pageId)"/>
          <xsl:variable name="outUrl">
             <xsl:choose>
                <xsl:when test="$pId != '' and $pId != '0' and $pId != 'undefined'">
                   <xsl:value-of select="umbraco.library:NiceUrl($pId)"/>
                </xsl:when>
                <xsl:otherwise>
                   <!--<xsl:text>/</xsl:text>-->
                   <xsl:value-of select="$currentPage/data [@alias = 'pageLinkConsument']"/>
                </xsl:otherwise>
             </xsl:choose>
          </xsl:variable>
          <xsl:value-of select="$outUrl"/>
       </xsl:template>
  • Petr Snobelt 923 posts 1535 karma points
    Dec 04, 2009 @ 16:29
    Petr Snobelt
    you can try add
    <textarea>
    <xsl:copy-of select="/macro" />
    </textarea>
    And check if it's passed to xslt.
    Maybe pageId is reserver parameter, try another name
    Dec 04, 2009 @ 16:44
    Bas Wensveen
    I found it, I didn't create a parameter in the macro parameter screen of Umbraco.
    Shame on me! :-)
    Thanks Petr Snobelt
