If you've got <head runat="server"> then you should be able to use an XSLT extension to set the <title> and find the meta description control/tag (easier to locate if you give it an ID and runat=server).
Otherwise you could try putting a macro in the <head> and generate/populate the title/meta-description from there, (which you'd probably already thought of).
I can't set the title in a macro in the header, as the content is decided by something going on further down the page. Usually you have the TITLE in your master page, and I want to change it to something else more or less dependant on the actual doc type. Fx. @nodeName is okay for all regular pages, but on all product pages I want the TITLE to be "Buy a @nodeName for only xxx DKK".
So I guess I should try and write and XSLT extension for this, if one doesn't exist already.
i'm pretty new at everything and i'm doing ok but something i just can't get to work i'm trying to set up a xslt file so my page title changes, but it wont grab the info out of my doc
this is my xslt file, somhow the information i put in at the tab sitename in my content manager doesn't appear in the page title:
@David: You're calling the siteName alias on both $homepageNode and on $currentPage, and in the latter case, it'll only work when you are actually on the homepage (which is then the $currentPage).
It looks like your example is a mix of pre-4.5 and post-4.5 XML schema, but on the new schema, I'd to this:
<!--If a node has content for the seoTitle property, output that--> <xsl:template match="*[normalize-space(seoTitle)]" mode="title" priority="1"> <xsl:value-of select="seoTitle"/> </xsl:template>
<!--If we're on the homepage, output the sitename and the site description--> <xsl:template match="HomePage" mode="title"> <xsl:value-of select="concat(siteName, ' - ', siteDescription)"/> </xsl:template>
<!--For all other pages, output the sitename and the name of the current page--> <xsl:template match="*" mode="title"> <xsl:value-of select="concat(ancestor-or-self::HomePage/siteName, ' - ', @nodeName)"/> </xsl:template>
Setting TITLE and META DESCRIPTION from macro
Hi everyone,
is is possible to set the page title and meta description from an XSLT macro further down the page?
I know I've seen the trick somewhere, just can't seem to find it again.
Best regards,
Soeren Sprogoe
Hi Soeren,
Cheers, Lee.
Hi Lee,
thanks for your reply.
Best regards,
Soeren Sprogoe
You should be able to write this as a XSLT Macro,
This could use xsl:choose, when parent id=shop section, then get the the title and also the price.
Should be really simple and no need for a custom extension.
/L
hi
<!DOCTYPE xsl:stylesheet [
<!ENTITY nbsp " ">
<xsl:stylesheet
version="1.0"
<xsl:variable name="homepageNode" select="$currentPage/ancestor::root/HomePage"/>
<xsl:template match="/">
<title>
<xsl:choose>
<xsl:when test="string-length($currentPage/data[@alias='seoTitle']) > 0">
<xsl:value-of select="$currentPage/data[@alias='seoTitle']"/>
</xsl:when>
<xsl:when test="$homepageNode/@id = $currentPage/@id">
<xsl:value-of select="$homepageNode/data[@alias='siteName']"/> - <xsl:value-of select="$homepageNode/data[@alias='siteDescription']"/>
</xsl:when>
<xsl:otherwise>
<xsl:value-of select="$currentPage/data[@alias='siteName']"/> | <xsl:value-of select="$currentPage/@nodeName"/>
</xsl:otherwise>
</xsl:choose>
</title>
</xsl:template>
</xsl:stylesheet>
Please help :D
@dan
thanks a million, this works like a charm.
now i can finally go on with the rest.
Thanks again
