Hi All
I am using Umbraco 4.0.2.1. And in my XSLT file I add following code
<img>
<xsl:attribute name="src"> <xsl:value-of select="umbraco.library:GetMedia($imageId, 'true')" /> </xsl:attribute>
</img>
However when I see it from page source, it adds extra staff into the image URL like:
http://www.mydomain.com/media/21850/testImage.jpg24324416926jpg
Can anyone help me how to solve this problem?
Thank you
Try changing the true value to false i.e. umbraco.library:GetMedia($imageId, 'false')
If that doesn't work can you post the complete XSLT
Cheers
Paul
Hi Jing,
The extra stuff you get is because GetMedia() returns an XML node - not just a string.
You should search the forum for "GetMedia" and "XSLT", as there are actually 1 or 2 answers given for this every week.
/Chriztian
Media nodes are slightly more confusing that normal nodes but this is what you actually need to do to get the source file path:
umbraco.library:GetMedia(@id, 'false')/data [@alias = 'umbracoFile']
The following post by Lee Kelleher on his blog should provide more detail on the subject:
http://blog.leekelleher.com/2009/11/30/how-to-use-umbraco-library-getmedia-in-xslt/
Thanks Simon. I got it solved
Problem with GetMedia
Hi All
<img>
</img>
Thank you
Cheers
Paul
Hi Jing,
/Chriztian
