umbraco v
4.0.2.1 (Assembly version: 1.0.3441.17657)
I've
made an usercontrol (using the Umbraco API) for letting members
add/edit their properties. My usercontrol works fine and the
new/modified data is stored in the DB. This is confirmed by checking
the umbraco backend. Also the usercontrol form is correctly updated.
I
also use an XSLT on other pages to display some of these properties.
I'm using <xsl:variable name="member"
select="umbraco.library:GetCurrentMember()" /> to retrieve the data
and then retrieving the correct property by<xsl:variable
name="aVariableName" select="$member/data [@alias='propertyName']"
For existing members, who have logged in earlier and
set/modified the properties, this works perfectly. They use the user
control and the new data is displayed on each page.
However, when
a new member logs in and modifies (actually setting) their properties,
the DB is updated but the Xslt doesn't show the changes. I've
discovered that when updating the usercontrol (the dll file itself),
umbraco does something (I'm guessing rebuilding a cache or something)
which makes the Xslt work for the new members.
Problem with GetCurrentMember
umbraco v 4.0.2.1 (Assembly version: 1.0.3441.17657)
I've made an usercontrol (using the Umbraco API) for letting members add/edit their properties. My usercontrol works fine and the new/modified data is stored in the DB. This is confirmed by checking the umbraco backend. Also the usercontrol form is correctly updated.
I also use an XSLT on other pages to display some of these properties. I'm using <xsl:variable name="member" select="umbraco.library:GetCurrentMember()" /> to retrieve the data and then retrieving the correct property by<xsl:variable name="aVariableName" select="$member/data [@alias='propertyName']" />.
For existing members, who have logged in earlier and set/modified the properties, this works perfectly. They use the user control and the new data is displayed on each page.
However, when a new member logs in and modifies (actually setting) their properties, the DB is updated but the Xslt doesn't show the changes. I've discovered that when updating the usercontrol (the dll file itself), umbraco does something (I'm guessing rebuilding a cache or something) which makes the Xslt work for the new members.
The submit button ends with the following code
member.XmlGenerate(new System.Xml.XmlDocument());
member.Save();
Member.RemoveMemberFromCache(member.Id);
Member.ClearMemberFromClient(member.Id);
Member.AddMemberToCache(member);
I'm guessing this is a bit of an overkill, but I've been struggeling for quite a while now.
Thanks!
