Hi all, this is probably really simple but...
I have an XSLT sort for records to show descending
<xsl:sort select="@id" order="descending"/>
The records in the database have now reached over 1000 and the sort has stopped at 999 records.
Here's the full XSLT:
<xsl:variable name="comments" select="UCommentLibrary:GetCommentsForNode($currentPage/@id)//comment"/> <h3> Showing 100 of <xsl:value-of select="count($comments)"/> comment<xsl:if test="count($comments) > 1">s</xsl:if> in our <xsl:value-of select="$currentPage/@nodeName"/> </h3> <ol class="commentlist"> <xsl:for-each select="$comments"> <xsl:sort select="@id" order="descending"/> <xsl:if test="position() <= 100"> <li class="comment" id="comment-{@id}"> <div class="comment-author"> <span class="fn n"> <xsl:value-of select="./name"/> </span> </div> <div class="comment-meta"> Posted <xsl:value-of select="umbraco.library:LongDate(@created,'true',' at ')"/> </div> <p> <xsl:value-of select="umbraco.library:ReplaceLineBreaks(./message)" disable-output-escaping="yes"/> </p> </li> </xsl:if> </xsl:for-each> </ol>
Can anyone help please?
many thanks!
Hi Roger,
Could very well just be that you need to tell the processor to sort numerical (the default is "text" - so you'll find item #1000 at the very end when sorting using descending) - try this:
<xsl:sort select="@id" data-type="number" order="descending" />
/Chriztian
Thanks Chriztian, worked perfectly :)
XSLT Sort Issue
many thanks!
Hi Roger,
/Chriztian
