  • Dan 1288 posts 3921 karma points c-trib
    Jan 07, 2010 @ 19:03
    Dan
    Simple variable passed into macro won't output value
    I'm trying to get a variable from a macro into XSLT and output in XHTML.  The variable is 'itemsPerLine'. The macro is:
    <umbraco:Macro Alias="Thumbnails" itemsPerLine="12" runat="server"></umbraco:Macro>
    The xslt is:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
    version="1.0"
    <!-- Input the repeatable custom contents property alias here -->
    <xsl:variable name="propertyAlias" select="string('column2')"/>
    <xsl:template match="/">
    <xsl:variable name="itemsPerLine" select="/macro/itemsPerLine"/>
    <xsl:if test="$currentPage/data [@alias = $propertyAlias]/items/item">
    <xsl:for-each select="$currentPage/data [@alias = $propertyAlias]/items/item">
    <div class="people margin height">
    <xsl:if test="string(current()/data[@alias='thumbnailImage1']) != ''">
    <xsl:element name="img">
    <xsl:attribute name="src">
    <xsl:value-of select="umbraco.library:GetMedia(current()/data[@alias='thumbnailImage1'], 'false')/data[@alias='umbracoFile']" />
    </xsl:attribute>
    <xsl:attribute name="alt">
    <xsl:value-of select="./data [@alias = 'thumbnailName']" disable-output-escaping="yes"/>
    </xsl:attribute>
    </xsl:element>
    </xsl:if>
    <div>
    <xsl:if test="string(current()/data[@alias='thumbnailImage2']) != ''">
    <xsl:value-of select="umbraco.library:GetMedia(current()/data[@alias='thumbnailImage2'], 'false')/data[@alias='umbracoFile']" />
    </xsl:attribute>
    </xsl:attribute>
    </xsl:element>
    </xsl:if>
    <h2>
    <xsl:value-of select="./data [@alias = 'thumbnailName']" disable-output-escaping="yes"/><xsl:value-of select="$itemsPerLine"/>
    </h2>
    <p><xsl:value-of select="./data [@alias = 'thumbnailText']" disable-output-escaping="yes"/></p>
    </xsl:for-each>
    <!-- Live Editing support for related links. -->
    <xsl:value-of select="umbraco.library:Item($currentPage/@id,$propertyAlias,'')" />
    </xsl:if>
    </xsl:template>
    </xsl:stylesheet>
    Can anyone see why this value doesn't output?
    Thanks all.
  • Douglas Robar 3570 posts 4711 karma points MVP ∞ admin c-trib
    Jan 07, 2010 @ 19:23
    Douglas Robar
    All look perfect. But... in the Macro itself (Developer section, Macro section of the treeview), have you added the itemsPerLine parameter? If not, your macro call can't pass values into the xslt. The Macro is the gateway (or 'api' if you will) between your umbraco:Macro call and the xslt or .net control that will process it.
    Let us know what you find out.
    cheers,
    doug.
    Jan 07, 2010 @ 21:07
    Dan
    You've opened up a world of new possibilities Doug!  Thanks very much, that's working now :)
