  • Devin 87 posts 251 karma points
    Mar 13, 2015 @ 09:43
    Devin
    Text string link problem
    Hi guys,
    When I put a full link in the text string using "http://www". the link works but if you only use "www", it just links to the node path.
    Any way around this? I want it so either way, the link will work with or without http://?
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
    version="1.0"
    xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:Examine="urn:Examine"
    exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets Examine ">
    <xsl:variable name="siteRoot" select="$currentPage/ancestor-or-self::* [@nodeTypeAlias='FrontPage']"/>
    <xsl:template match="/">
    <xsl:variable name="facebook" select="$siteRoot/facebook"/>
    <xsl:variable name="twitter" select="$siteRoot/twitter"/>
    <xsl:variable name="googlePlus" select="$siteRoot/googlePlus"/>
    <xsl:variable name="linkedIn" select="$siteRoot/linkedIn"/>
    <xsl:variable name="instagram" select="$siteRoot/instagram"/>
    <ul id="socialIcons">
    <xsl:if test="$facebook != ''">
    <li>
    <a href="{$facebook}" target="_blank">
    <div id="facebook"><xsl:value-of select="normalize-space('')"/></div>
    </a>
    </li>
    </xsl:if>
    <xsl:if test="$twitter != ''">
    <li>
    <a href="{$twitter}" target="_blank">
    <div id="twitter"><xsl:value-of select="normalize-space('')"/></div>
    </a>
    </li>
    </xsl:if>
    <xsl:if test="$googlePlus != ''">
    <li>
    <a href="{$googlePlus}" target="_blank">
    <div id="googlePlus"><xsl:value-of select="normalize-space('')"/></div>
    </a>
    </li>
    </xsl:if>
    <xsl:if test="$linkedIn != ''">
    <li>
    <a href="{$linkedIn}" target="_blank">
    <div id="linkedIn"><xsl:value-of select="normalize-space('')"/></div>
    </a>
    </li>
    </xsl:if>
    <xsl:if test="$instagram != ''">
    <li>
    <a href="{$instagram}" target="_blank">
    <div id="instagram"><xsl:value-of select="normalize-space('')"/></div>
    </a>
    </li>
    </xsl:if>
    </ul>
    </xsl:template>
    </xsl:stylesheet>
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 9x admin c-trib
    Mar 13, 2015 @ 09:59
    2
    Hi Devin,
    Have a look at this way of doing it - it's a totally different (yet more "XSLT-like") approach, I know, but you may like it :-)
    At least you should be able to see how you can actually rewrite an attribute depending on some condition, which is what you're looking for...
    <?xml version="1.0" encoding="utf-8" ?>
    <xsl:stylesheet
        version="1.0"
        xmlns:umb="urn:umbraco.library"
        exclude-result-prefixes="umb"
        <!-- Use HTML mode to avoid hacking empty output elements -->
        <xsl:output method="html" indent="yes" omit-xml-declaration="yes" />
        <xsl:param name="currentPage" />
        <xsl:variable name="siteRoot" select="$currentPage/ancestor-or-self::FrontPage" />
            <!-- If no fields are filled, don't output anything -->
            <xsl:apply-templates select="$siteRoot[normalize-space(concat(facebook, twitter, googlePlus, linkedIn, instagram))]" />
        </xsl:template>
        <xsl:template match="FrontPage">
                <xsl:apply-templates select="facebook" mode="link" />
                <xsl:apply-templates select="twitter" mode="link" />
                <xsl:apply-templates select="googlePlus" mode="link" />
                <xsl:apply-templates select="linkedIn" mode="link" />
                <xsl:apply-templates select="instagram" mode="link" />
            </ul>
        </xsl:template>
        <!-- Generic output template for all services -->
        <xsl:template match="*" mode="link">
            <li>
                <a href="{.}" target="_blank">
                    <!-- Rewrite href attribute if needed -->
                    <xsl:if test="not(starts-with(., 'http'))">
                        <xsl:attribute name="href">
                            <xsl:value-of select="concat('http://', .)" />
                        </xsl:attribute>
                    </xsl:if>
                    <div id="{name()}">
                        <!-- Output service name for accessibility (hide with CSS)? -->
                        <!-- <xsl:value-of select="name()" /> -->
                </a>
            </li>
        </xsl:template>
        <xsl:template match="*[not(normalize-space())]" mode="link">
            <!-- No output for empty services -->
        </xsl:template>
    </xsl:stylesheet>
    /Chriztian
    Mar 13, 2015 @ 10:17
    Devin
    You always kill it when it comes to XSLT haha. Thank you greatly, this is perfect. :)
    Definitely an interesting way of doing it.
    Mar 13, 2015 @ 10:32
    Haha - kind words, thanks :-)
  • Daniel 3 posts 73 karma points
    Apr 20, 2018 @ 08:39
    Daniel
    HI Chris .Please can you help with XSLT
    Hi all,
    I have a ticketing system which receives emails formatted in xml sent by users. The system uses an xslt script to convert the xml formatted email into the supported xml format that the system uses to create a ticket.
    Below is an example of the email format which is sent to the system:
    The content found between the tag Description is copied into the description of the ticket is below:
    First Name: Paul Last Name: Bonthuys Email Address: paul.b@yahoo.com Contact Number: 0123456789 How can we help you: Testing
    The issue I am having is that all the text after the email address is cut and not displayed in the ticket description field. So the description field only shows as below:
    Of course I have the option of moving the email address to the end of the Description tag, but I will like to keep the sequence of how the information is displayed i.e. First Name, Last Name, Email Address, Contact Number. I am suspecting that the email address hyperlink is causing the text after it to be cut and not being displayed.
    Below is a sample of my xslt script which copies the content of my email into the ticket description field:
    Anyone has an idea of how I could strip the hyperlink in the email address so that some texts are not cut? XSLT CODE
                                <xsl:variable name="Subject" select = "BusinessObjectList/BusinessObject/EmailMessage/Subject"/>
                                                <xsl:choose>
        <xsl:when test="contains($Subject,'Incident#')">
        <xsl:call-template name="INCIDENT-UPDATE"/>
        </xsl:when>
        <xsl:when test="contains(translate($Subject,'ABCDEFGHIJKLMNOPQRSTUVWXYZ','abcdefghijklmnopqrstuvwxyz'), 'printer')">
        <xsl:call-template name="INCIDENT-KEYWORD-PRINTER"/>
        </xsl:when>
        <xsl:when test="contains(translate($Subject,'ABCDEFGHIJKLMNOPQRSTUVWXYZ','abcdefghijklmnopqrstuvwxyz'), 'outlook')">
        <xsl:call-template name="INCIDENT-KEYWORD-OUTLOOK"/>
        </xsl:when>
        <xsl:when test="contains($Subject,'Service Request#')">
        <xsl:call-template name="SERVICE-REQUEST-UPDATE"/>
        </xsl:when>
        <xsl:when test="contains($Subject,'Task#')">
        <xsl:call-template name="TASK-UPDATE"/>
        </xsl:when>
        <xsl:otherwise>
        <xsl:call-template name="INCIDENT-NEW" />
        </xsl:otherwise>
                                                </xsl:choose>
                                </BusinessObjectList>
                </xsl:template>
                <xsl:template name="INCIDENT-NEW">
                                                Erzeugt aus der e-Mail den XML Code zum Aktualisieren Anlage eines neuen Incidents
                                                - Die Attachments werden dem Incident hinzugefügt
                                                Beispielaufruf:
    <!-- find the profile link recid of the email sender -->
                                <xsl:variable name="profilelink_recid">
                                <!-- for each RelatedBusinessObject -->
                               <xsl:for-each select="BusinessObjectList/BusinessObject/RelatedBusinessObjectList/RelatedBusinessObject/BusinessObject">
                                                <xsl:choose>
        <xsl:when test="@Name = 'Employee'">
        <xsl:for-each select="./FieldList/Field">
        <xsl:choose>
        <xsl:when test="@Name = 'RecId'">
        <!-- <xsl:value-of select="."/>-->
        <xsl:value-of select="'620F9E6687914E61A386572763768870'"/>
        </xsl:when>
        </xsl:choose>
        </xsl:for-each>
        </xsl:when>
                                                </xsl:choose>
                                </xsl:for-each>
                                </xsl:variable>
    <!-- find the profile link category of the email sender -->
                                <xsl:variable name="profilelink_cat">
                                                <xsl:choose>
        <xsl:value-of select="'Employee'"/>
        </xsl:when>
                                                </xsl:choose>
                                </xsl:for-each>
                                </xsl:variable>
    <!-- for each BusinessObject -->
                                <xsl:for-each select="BusinessObjectList/BusinessObject">
                                <!-- Set the BO name -->
                                <xsl:element name="BusinessObject">
        <!-- Set BO Name as 'Incident' -->
                                                <xsl:attribute name="Name">
        <xsl:value-of select="'Incident'"/>
                                                </xsl:attribute>
        <!-- Set Transaction as 'Insert' -->
        <xsl:element name="Transaction">UpdateAdd</xsl:element>
        <!--Unique Key List-->
        <xsl:element name="UniqueKeyList">
                                                <xsl:element name="UniqueKey">
        <xsl:element name="Field">
        <xsl:value-of select="'IncidentNumber'"/>
        </xsl:attribute>
        </xsl:element>
                                                </xsl:element>
        </xsl:element>
        <!-- Field List -->
        <FieldList>
          <!-- Fields -->
                                    <xsl:for-each select="EmailMessage/node()">
                                    <xsl:choose>
        <!-- Incident.Subject = Email.Subject-->
        <xsl:when test="name() = 'Subject'">
        <xsl:value-of select="'Subject'"/>
        </xsl:attribute>
        <xsl:attribute name="Type">System.String</xsl:attribute>
        </xsl:element>
        <xsl:value-of select="'Category'"/>
        </xsl:attribute>
        </xsl:element>
        </xsl:when>
        <xsl:when test="name() = 'Body'">
        <xsl:variable name="emailbody" method="html" indent="yes" >
                                </xsl:element>
    </xsl:for-each>
                </xsl:template>
    TIA.
