  • Abdullah Anwar 36 posts 56 karma points
    Mar 17, 2015 @ 09:32
    Abdullah Anwar
    Anchor Tag href Problem
    I am trying to use javascript in anchor tag href in rich text editor but its not accepting.
    Code that i am using
    <a href="javascript:;">Service</a>
    but it converts into
    <a >Service</a>
    Why its happening
    Could you please help me to solve?
    Mar 17, 2015 @ 11:25
    Hi Abdullah
    What exact version of Umbraco are you using?
    In some versions tidy is being used to wipe out bad markup and inline javascript etc. - However it has been disabled in v6 and later by default. But I suspect that it still does some cleaning anyway.
    But you can try to configure /config/TinyMceConfig.config file to allow all elements by just having * where all the elements are currently defined.
    But why do you want to setup inline javascript on an anchor tag in the rich text editor? What is the scenario? Perhaps there is a better way around it so you don't mix content and code.
    Mar 17, 2015 @ 11:33
    Abdullah Anwar
    Thanks Jan :)
    Mar 17, 2015 @ 11:38
    Hi Abdullah
    You're welcome - did it help any? :)
    Mar 17, 2015 @ 12:11
    Abdullah Anwar
    yes, it worked for me.
    Mar 17, 2015 @ 12:27
    Ok, happy I could help - Could you please mark the issue as solved so other who may come across the same challenge can go straight to the solution? :)
    Happy coding!
