  • Darryl Godden 145 posts 197 karma points
    Jan 19, 2010 @ 14:19
    Darryl Godden
    Problem with XSLT (after trying a variety of examples)
    I'm using this XSLT:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
        version="1.0"
    <xsl:template match="/">
    <html>
    <body>
    <ul>
        <li><xsl:value-of select="$currentPage/node/node [@alias='tagLine']/text()"/></li>
    </ul>
    </body>
    </html>
    </xsl:template>
    </xsl:stylesheet>
    As a test to show the contents of a node, but I'm not getting any output in the XSLT Visualizer. Are there any glaring mistakes you can see?
    Darryl
    Jan 19, 2010 @ 14:28
    Dirk De Grave
    need to use
    <xsl:value-of select="$currentPage/data [@alias='tagLine']"/>
    instead of your xslt statement.
    Explanation: custom properties can be found on a /data subnode
    /Dirk
    Jan 19, 2010 @ 14:30
    Darryl Godden
    Just tried it and there's no output...
    Would it help to post the umbraco.config?
    Jan 19, 2010 @ 14:33
    Dirk De Grave
    yup, would be great to see that portion of the xml
    /Dirk
  • Lee Kelleher 4026 posts 15836 karma points MVP 13x admin c-trib
    Jan 19, 2010 @ 14:36
    Lee Kelleher
    Hi Darryl,
    No need to post your umbraco.config.
    Try the following XSLT to see the XML content of the $currentPage:
    <xmp>
        <xsl:copy-of select="$currentPage" />
    </xmp>
    If you need help understanding how the $currentPage works, take a read of the wiki page about it.
    http://our.umbraco.org/wiki/reference/xslt/understanding-currentpage
    If you still need help, come back here.
    Cheers, Lee.
    Darryl Godden
    Oki doke, here goes:
    <!DOCTYPE umbraco[ <!ELEMENT nodes ANY>  <!ELEMENT node ANY>  <!ATTLIST node id ID #REQUIRED> ]>
    <root id="-1">
      <node id="1080" version="6adffe02-d31c-4925-89b4-e8d26bc51961" parentID="-1" level="1" writerID="0" creatorID="0" nodeType="1078" template="1079" sortOrder="2" createDate="2010-01-18T15:09:14" updateDate="2010-01-18T15:23:32" nodeName="Home" urlName="home" writerName="Administrator" creatorName="Administrator" nodeTypeAlias="Home" path="-1,1080">
        <data alias="rubbish"><![CDATA[
    <p>hjkhjkhjkhjkghjkhjkghkhjkhjkhkjhjkhjkhgjk</p>
    ]]></data>
        <data alias="script"><![CDATA[]]></data>
        <data alias="pagetitle">Home - Raymond Gubbay</data>
        <data alias="metadescription">
        </data>
        <data alias="metakeywords">
        </data>
        <data alias="shorttitle">
        </data>
        <node id="1088" version="c01ad430-aebe-4655-85d7-3483caec051e" parentID="1080" level="2" writerID="0" creatorID="0" nodeType="1081" template="1082" sortOrder="1" createDate="2010-01-18T16:58:13" updateDate="2010-01-18T16:58:34" nodeName="whatson" urlName="whatson" writerName="Administrator" creatorName="Administrator" nodeTypeAlias="Article" path="-1,1080,1088">
          <data alias="pagecontent"><![CDATA[]]></data>
          <data alias="html"><![CDATA[]]></data>
          <data alias="pagetitle">What's On - Raymond Gubbay</data>
          <data alias="metadescription" />
          <data alias="metakeywords" />
          <data alias="shorttitle" />
          <node id="1089" version="e2e39ff5-4791-4348-85a9-fcb5fc5cfc19" parentID="1088" level="3" writerID="0" creatorID="0" nodeType="1085" template="0" sortOrder="1" createDate="2010-01-19T09:41:43" updateDate="2010-01-19T09:43:51" nodeName="Tom Jones" urlName="tom-jones" writerName="Administrator" creatorName="Administrator" nodeTypeAlias="Event" path="-1,1080,1088,1089">
            <data alias="venue"><![CDATA[Bristol Hippodrome]]></data>
            <data alias="description"><![CDATA[Tom Jones returns, yes he's still going folks]]></data>
            <data alias="category"><![CDATA[Concert]]></data>
            <data alias="imagemedium">/images/tj.png</data>
            <data alias="imagesmall">/images/tj_small.png</data>
            <data alias="tagline">Tom Jones live</data>
    So the ideal thing is to get items like the tagLine etc...
    Darryl
    Jan 19, 2010 @ 15:00
    Darryl Godden
    Gah! Case sensitivity of XML, tagLine is actually tagline...
    Working version:
    <xsl:stylesheet
        version="1.0"
    <html>
    <body>
    <ul>
        <li><xsl:value-of select="$currentPage/data [@alias='tagline']"/></li>
    </ul>
    </body>
    </html>
    </xsl:template>
