(not so) funny xslt-error with 'key' and 'for-each'
This error must be because of some error in my node-structure, or what?
I have a xslt for a dropdown that are supposed to write a list of cities where companies are located, and every city only once (like sql select distinct).
I works well except for the fact it excludes "Stockholm" (!). There are companies with City='Stockholm' I can assure you, but why does my XSLT not catch that?
Now I know you start to doubt my sanity, or my eyes at least, but I changed back to Stockholm, and *gone*, the capitol of Sweden just wont show up in that list.
This actually works (vb-code called from within xslt), if someone needs proof, I give you the login to my site:
Public Function createListOfCities(ByVal nodeId As Integer) As String
Dim myNode = New Node(nodeId)
Dim resultHtml As New Text.StringBuilder
If myNode.Children.Count > 0 Then
resultHtml.Append("<ul>")
Dim city As String = ""
Dim listOfCities As New List(Of String)
For Each childNode As Node In myNode.Children
city = childNode.GetProperty("City").Value
If Not (listOfCities.Contains(city)) Then l.Add(city)
Next nn
listOfCities.Sort()
For Each sortedCity As String In listOfCities
resultHtml.Append("<li>")
resultHtml.Append(sortedCity)
resultHtml.Append("</li>")
Next sortedCity
resultHtml.Append("</ul>")
End If
Return resultHtml.ToString()
End Function
(I did a <ul> just for testing, should find a way for it to sort with swedish chars, then I'll make it a dropdown.)
Staffanstorp, Stenungsund, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Strömstad, Sundsvall, Sundsvall, Sundsvall, Sundsvall, Sundsvall, Svenljun
OK so we definately know its something to do with that XSLT in the for-each then.
I thought I had done some stuff with disctinct and XSLT, but I must have imagined it. However someone has a nice blog post that should help you to solve this.
I buy a license of Contour to the first one who solves this :-) For sure, I do! I'm not sure I can assist you with live testing very much though, let me get back on that if that's needed.
So weird it is it works for me. Why not for you? btw: which umbraco version do you use on which Os do you work and which language settings do you have?
Thanks guys, the best guess I have right now is that some odd char has gone into the field 'City' just for 'Stockholm' and breaks things (dunno how, but...) Also I haven't looked for all other cities, does seem complete though, should count them.
agree, try to recycle the app pool to get the cache cleared. Also check the caching settings of the macro. I have tested the special characters in my solution and it had no probs...
Ah, yes Peter, thanks, same thought. But how to do that quick n easy? With a function? There are some hundred companies in the list.
And oh, Umbraco version is 4.0.3. Language settings, in umbraco? Swedish. In SQL SQL_Latin1_General_CP1_CI_AS. Server "Current format" English (United States) (That's what lang settings I can think of)
Must be something strange with my node data, right? I'm struggling with this, but the xslt seem perfectly alright, doesn't it? So please, thanks for your help so far, no need to take your time more, if you don't want to ofcourse, the Contour-offer is still there, any suggestions of how to find out the erroneous node data (if thats what it is) or any other thougts are welcome! I'm of to bed now, have to sleep on this one.
Thank you all, Warren, Criztian, Thomas & Peter. The actual error was in the xml somewhere, no one gave me the exact solution, but I like to give away my "price" anyway and I believe Criztians guess was the first on spot "I'm guessing there's a discrepancy between the published node tree and the tree you're getting from GetXmlNodeById()...". Ok Thomas? Also it was kind'a informative to use Criztians xmldump on the tree.
Oh, the solution : I copied the whole company tree to another so umbraco could recreate all nodes.
Still one wonders why this happened. I did not inform you about the companies is imported from an external db. And first version of the import was not 100% bugfree whith publishing, so perhaps errors come from that.
A word about the "contest". It's not my intention to start some habit here. The forum is the best and a friendly and helpful one, without giveaways. I was quite desperate and really stuck. And very tired. And also I just started to play with Contour and thought is was a fun idea to buy a license for the one helps me out. Ok folks? :)
BTW: Some motivation is always good ;-), although the main motivation by the
most of us is to help others to let the umbraco community be the best
commnity ever. And for sure it is ok to give the 'price' ti Criztian, he had the right intention.
The most important point is: this problem is solved...
<xsl:key name="nodes-by-City" match="node" use="data [@alias='City']" /> <xsl:template match="/"> <select id="location" name="location"> <option value="0">Choose location</option> <xsl:for-each select="umbraco.library:GetXmlNodeById($companiesRoot)/node [count(. | key('nodes-by-City', data [@alias='City'])[1]) = 1]"> <xsl:sort select="data [@alias='City']" lang="sv" /> <option value="{data [@alias='City']}"> <xsl:value-of select="data [@alias='City']" /> </option> </xsl:for-each> </select> </xsl:template>I works well except for the fact it excludes "Stockholm" (!). There are companies with City='Stockholm' I can assure you, but why does my XSLT not catch that?
Huh!! I changed the city to "Stoockholm" and that showed up in the drop-down. This sure is a strange one!
aah, perhaps that '=1' is wrong... :-p
Nope... Here's the point where I leave XSLT for this macro and add some .NET-code instead. :-o
Better looking solution:
<xsl:template match="/"> <select id="location" name="location"> <option value="0">Välj stad</option> <xsl:for-each select="umbraco.library:GetXmlNodeById($companiesRoot)/node [not(./data [@alias='City']=preceding::data [@alias='City'])]"> <xsl:sort select="data [@alias='City']" lang="sv" /> <option value="{data [@alias='City']}"> <xsl:value-of select="data [@alias='City']" /> </option> </xsl:for-each> </select> </xsl:template>This actually works (vb-code called from within xslt), if someone needs proof, I give you the login to my site:
Public Function createListOfCities(ByVal nodeId As Integer) As String Dim myNode = New Node(nodeId) Dim resultHtml As New Text.StringBuilder If myNode.Children.Count > 0 Then resultHtml.Append("<ul>") Dim city As String = "" Dim listOfCities As New List(Of String) For Each childNode As Node In myNode.Children city = childNode.GetProperty("City").Value If Not (listOfCities.Contains(city)) Then l.Add(city) Next nn listOfCities.Sort() For Each sortedCity As String In listOfCities resultHtml.Append("<li>") resultHtml.Append(sortedCity) resultHtml.Append("</li>") Next sortedCity resultHtml.Append("</ul>") End If Return resultHtml.ToString() End FunctionHi Jonas,
Have you simplified your XSLT for debugging first?
eg
Does the missing node now output, if so we can now identify that its this line that needs fixing.
Warren
Hi Warren! Thanks for being with me here. :-)
I change to this:
<xsl:for-each select="umbraco.library:GetXmlNodeById('6850')/node"> <xsl:sort select="data [@alias='City']"/> <xsl:value-of select="data [@alias='City']"/>, </xsl:for-each>And the output (some of it):
Staffanstorp, Stenungsund, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Stockholm, Strömstad, Sundsvall, Sundsvall, Sundsvall, Sundsvall, Sundsvall, SvenljunOK so we definately know its something to do with that XSLT in the for-each then.
http://blackpoint.dk/umbraco-workbench.aspx?Snippet=/umbraco-workbench/xslt/grouping--distinct-values.aspx
Warren
Thanks, but that did not work either (!)
<xsl:key name="nodes-by-City" match="node" use="data [@alias='City']" /> <xsl:template match="/"> <select id="location" name="location"> <option value="0">Choose location</option> <xsl:for-each select="umbraco.library:GetXmlNodeById(6850)/node[generate-id() = generate-id(key('nodes-by-City', data [@alias='City'])[1])]"> <xsl:sort select="data [@alias='City']" lang="sv" /> <option value="{data [@alias='City']}"> <xsl:value-of select="data [@alias='City']" /> </option> </xsl:for-each> </select> </xsl:template>I'm off to sleep now. I would be the happiest umbracian if I got help with this during the night. See ya.
I'm pretty sure some of you don't believe this error (?) :-o... I have a lot other stuff to finish, but I will keep you updated on this...
Hi Jonas - I *do* believe you :-)
Trying a couple of things... will return.
/Chriztian
Hi Jonas, I did set up a node with some subnodes with the property City. Then I tried you last code and it worked for me:
The code:
the output: http://blog.thoehler.com/test/city-start
Thomas
My 2 cents: names with special characters can have weird effect on some things. ë, ï, ö, etc.
Try renaming cities that have a special char to the name without that char and see if that helps.
Somehow the community will get this fixed ;-)
Hi Jonas,
All tests return the same here: Stockholm exists :-)
/Chriztian
Thomas
I think you are right. to solve this one may have access to the backend. If you want I have some minutes left...
Thomas
How to clean up messy nodes best?
I tried republish (on root companynode as well as content root). Also I made the app-pool recycle (by adding a space in web.config).
Criztians, please mejl me jonas programenta.se
Glad that it is solved.
BTW: Some motivation is always good ;-), although the main motivation by the most of us is to help others to let the umbraco community be the best commnity ever. And for sure it is ok to give the 'price' ti Criztian, he had the right intention.
Thomas
Thank you Thomas :-)
Just for the record, Contour is bought and delivered (well the license anyway). Have fun with Contour and good luck with that site Criztian!
For all readers, this thread shows 4 ways of doing Select Disctinct, all work (right?), if the nodes are ok, not bad eh?
Happy coding to all!
/Jonas
