I have a simple structure in my site tree.
Home
Subpage1
SubSub1
SubSub2
Subpage2
Subpage3
My XSLT is based on the standard template but I added support to display the SubSub leves in an <ul>. This works kinda almost ;)
If I browse to Home, Sub1,2,3 is displayed like it should. Browsing to Subpage1 displays SubSub1 and SubSub2 in a <ul> beneath Sub1. So far so good.
Now, if I browse to Sub2 I get Sub3 (and every other SubX) in a <ul> like the SubSub's and I can't figure out why.
Here is my XSLT.
<xsl:output method="xml" omit-xml-declaration="yes" /> <xsl:param name="currentPage"/> <xsl:variable name="level" select="1"/> <xsl:template match="/"> <!-- The fun starts here --> <ul> <xsl:for-each select="$currentPage/ancestor-or-self::node [@level=$level]/node [string(data [@alias='umbracoNaviHide']) != '1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:if test="$currentPage/ancestor-or-self::node/@id = current()/@id"> <xsl:attribute name="style">font-weight: bold;</xsl:attribute> </xsl:if> <xsl:value-of select="@nodeName"/> </a> </li> <xsl:if test="$currentPage/ancestor-or-self::node/@id = current()/@id"> <ul> <xsl:for-each select="node"> <li> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="@nodeName"/> </a> </li> </xsl:for-each> </ul> </xsl:if> </xsl:for-each> </ul> </xsl:template>
Help!
/Another Fredrik
Ok, so I guessing im selecting something wrong in the
but I can't figure out what it really should be :(
I would recommend uisng the "Cogwork Flexible Navigation" Package.
It takes a lot of stress out of simple navigtaion, like the one your trying to build.
http://our.umbraco.org/projects/cogworks---flexible-navigation
Ah, it looks great. I'll check it out. Still interested to find out what I did wrong so I can learn something :)
Hi Frederik
You could try this one out:
<xsl:variable name="rootNode" select="$currentPage/ancestor-or-self::node [@level=2]" /><xsl:param name="currentPage"/> <xsl:template match="/"> <ul id="subMenu"> <!-- display normal umbraco navigation, take the tree from the active section --> <xsl:apply-templates select="$currentPage/ancestor-or-self::node [@level=2]/node [string(data [@alias='umbracoNaviHide']) != '1']"/> <li class="hide"> <p> </p> </li> </ul> </xsl:template> <xsl:template match="node[string(data [@alias='umbracoNaviHide']) != '1']" xml:space="default"> <xsl:variable name="id" select="id" /> <li class="subNiveau"> <xsl:attribute name="class">subNiveau<xsl:if test="$currentPage/ancestor-or-self::node/@id = current()/@id"> current</xsl:if><xsl:if test="$currentPage/ancestor::node[@id = $id]"> ancestor</xsl:if> </xsl:attribute> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="@nodeName" disable-output-escaping="yes"/> </a> </li> <xsl:if test="count(./node) > 0 and count(descendant-or-self::node [@id = $currentPage/@id]) > 0 and ./node[@level < 5]"> <li class="subMenu2"> <ul> <xsl:apply-templates select="./node" /> </ul> </li> </xsl:if> </xsl:template>
This works for me, and I use it everytime I need a submenu on one of my sites.
/Kim A
Thanks Kim, looks quite similar to mine.
Good to hear Frederik. It could be cool if you would report back, whether your problem was solved or not.
Upload image
Menu, submenu problem
Here is my XSLT.
Help!
/Another Fredrik
/Another Fredrik
Hi Frederik
/Kim A
/Kim A
