I figure we need to start this topic and since i cannot figure this out... i am asking for help :)
i can see glimpses of the new syntax in the stock xslt that comes with install -- looks very cool and it also looks like the data[@alias=''] syntax might be going away.
can someone please post a getMedia example here... as i think even in the current versions, this is one of the most challenging xslt items we face.
Just tried to use GetMedia on a fresh v4.1 install, but no joy - not sure what the issue is (haven't got time to raise a CodePlex issue at the moment either - may do later).
If you can get it to work, then try the usual <xmp> tags to see what is being pulled back from GetMedia?
4.1 xslt syntax help an hints
thanks!
Hi Bob,
Yes you are right the main reason for changing the XML was to get rid of the data[@alias=''] syntax to make it easy for new users to understand.
Sorry I've not had time to create an example, but I am sure someone will post one shortly :)
Chris
<xmp> <xsl:copy-of select="umbraco.library:GetMedia(1055, 0)" /> </xmp>Cheers, Lee.
yeah, it looks to be a bit broken... i can get it to work in legacy mode... but really want to start working with the new syntax to get used to it.
