Hey.
iam tryning to get the following topnavination menu convertede to a XSLT dut iam not so dam good in version 7 yet.
this is the one i use in my version 6 site in the scripting files.
@inherits umbraco.MacroEngines.DynamicNodeContext @{ @*Get the toot og the website *@ var root = Model.AncestorOrSelf(1).Children.Where("Visible"); } <ul> <li><a href="/">FORSIDE</a></li> @foreach (var page in root) { <li class="@page.IsAncestorOrSelf(Model, "current-menu-item", "")"> <a href="@page.Url">@page.Name</a> @* check if page has chrildren *@ @if (page.Children.Where("Visible").Count() > 0) { <ul> @foreach (var subpage1 in page.Children.Where("Visible")) { <li> <a href="@subpage1.Url">@subpage1.Name</a> } </li> } </ul> } </li> } </ul>
I love to get it over to XSLT. and i dit try but i cant get it to work.
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Examine="urn:Examine" exclude-result-prefixes="msxml umbraco.library Examine "> <xsl:output method="xml" omit-xml-declaration="yes" /> <xsl:param name="currentPage"/> <!-- Input the documenttype you want here --> <!-- Typically '1' for topnavigtaion and '2' for 2nd level --> <!-- Use div elements around this macro combined with css --> <!-- for styling the navigation --> <xsl:variable name="level" select="1"/> <xsl:template match="/"> <!-- The fun starts here --> <ul class="nav navbar-nav navbar-right"> <li> <a href="#" class="" data-toggle="dropdown">Velkommen</a> </li> <xsl:for-each select="$currentPage/ancestor-or-self::* [@isDoc and @level=$level]/* [@isDoc and string(umbracoNaviHide) != '0']"> <li class="dropdown"> <a href="{umbraco.library:NiceUrl(@id)}" class="dropdown-toggle" data-toggle="dropdown"><xsl:value-of select="@nodeName"/></a> <ul class="dropdown-menu"> <li class=""> <a href="{umbraco.library:NiceUrl(@id)}" class="dropdown-toggle" data-toggle="dropdown"><xsl:value-of select="@nodeName"/></a> </li> </ul> </li> </xsl:for-each> </ul> </xsl:template> </xsl:stylesheet>
i hope som can help me..
i noly need it to list subpages one lvl down
like this.
page pagesub
Michael
Hi Michael,
Since you are using Umbraco 7 I can help you convert it to a partial view or partial view macro file.
Try to use this code below
@{ @*Get the toot og the website *@ var root = CurrentPage.AncestorOrSelf(1).Children.Where("Visible"); } <ul> <li><a href="/">FORSIDE</a></li> @foreach (var page in root) { <li class="@page.IsAncestorOrSelf(CurrentPage, "current-menu-item", "")"> <a href="@page.Url">@page.Name</a> @* check if page has chrildren *@ @if (page.Children.Where("Visible").Any()) { <ul> @foreach (var subpage1 in page.Children.Where("Visible")) { <li> <a href="@subpage1.Url">@subpage1.Name</a> } </li> } </ul> } </li> } </ul>
If you are using Partial view then you need to add this in the top of the file,
Try to see this documentation https://our.umbraco.org/documentation/Reference/Templating/Mvc/partial-views
If you are using a Partial view macro file, then you would need to add this to the top of the file.
Try to see the documentation here https://our.umbraco.org/documentation/Reference/Templating/Macros/Partial-View-Macros/ and https://our.umbraco.org/documentation/Reference/Templating/Mvc/views
Hope this helps,
/Dennis
Dropdown Topnavigation problem.
Hey.
like this.
page pagesub
Michael
Hi Michael,
Hope this helps,
/Dennis
