Can't believe I haven't ran into this before but I'm trying to create a URL using an xsl:variable but can't find the correct way to add query string parameters.
I want to render an <img> tag but the source URL of which is created dynamically, (for WebTrends). The "WT" variable is where I intended the magic to happen but I just can't the "&" in the query string parameters without either:
Thinking about this for another few seconds I'm not sure you'll even need the disable-output-escaping="yes" portion of the <xsl:text> tag. Try it without first and you should be okay.
Do bear in mind that though you don't usually see & on the querystring of a browser it is perfectly valid and supported by all browsers, so don't let it bother you if the url you end up with has & in it rather than the shortened & only... both work just fine in the real world. :)
I always though it had to be "&" not "&". Its crucial that the query string parameters are retrievable - otherwise the WebTrends tracking will not work.
Note that replacing & with
& is only done when
writing the URL
in
HTML,
where "&" is a special character (along with "<"
and ">"). When writing the same
URL
in a plain text email message or in the location bar of your browser,
you would use "&" and not "&". With
HTML,
the browser translates "&" to "&" so the Web server would
only see
"&" and not "&" in the query string of the request
XSLT problem
Thanks for any help,
The problem is that the ampersand character is a 'special' character in XSLT, so it must be escaped in your xslt, as &
In your code, I would do something like this:
or...
cheers,
doug.
cheers,
doug.
Hi Neil,
Remember CDATA is your friend! (modifications in bold below)
<?xml version="1.0" encoding="utf-8"?> <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> <!ENTITY amp "&"> ]> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" exclude-result-prefixes="msxml umbraco.library"> <xsl:output method="xml" omit-xml-declaration="yes" encoding="utf-8" /> <xsl:param name="currentPage"/> <xsl:variable name="WTdomain" select="umbraco.library:GetDictionaryItem('WebTrendsDomain')" /> <xsl:variable name="WTid" select="umbraco.library:GetDictionaryItem('WebTrendsID')"/> <xsl:variable name="WTurl"> <xsl:value-of select="concat('http://', $WTdomain, '/', $WTid, '/dcs.gif?')" /> <!-- Query string parameters --> <xsl:text><![CDATA[WT.seg_2=mobile&RAND=53335]]></xsl:text> </xsl:variable> <xsl:template match="/"> <xsl:comment> <xsl:text disable-output-escaping="yes">Render WT tag </xsl:text> <xsl:value-of select="$WTdomain" /> <xsl:text disable-output-escaping="yes"> - </xsl:text> <xsl:value-of select="$WTid" /> </xsl:comment> <xsl:text> 	</xsl:text> <!-- image tag --> <img alt="." width="1" height="1"> <xsl:attribute name="src"> <xsl:value-of select="$WTurl" disable-output-escaping="yes" /> </xsl:attribute> </img> </xsl:template> </xsl:stylesheet>Cheers, Lee.
As Doug pointed out, this results in the following URL:
dcs.gif?WT.seg_2=mobile&RAND=11111I always though it had to be "&" not "&". Its crucial that the query string parameters are retrievable - otherwise the WebTrends tracking will not work.
Neil
In fact, using "&" only breaks xhtml validation. Browsers can work with both though so it's not something to worry about. From the linked page...
To avoid problems with both validators and browsers, always use & in place of & when writing URLs in HTML:
<a href="foo.cgi?chapter=1&section=2&copy=3&lang=en">...</a>Note that replacing & with & is only done when writing the URL in HTML, where "&" is a special character (along with "<" and ">"). When writing the same URL in a plain text email message or in the location bar of your browser, you would use "&" and not "&". With HTML, the browser translates "&" to "&" so the Web server would only see "&" and not "&" in the query string of the request
Dan
Thanks Dan,
But when I click the created link:
the browser (Chrome) windows open with the "&" intact in the address bar. That's to be expected? It wouldn't "translate" the "&" back to "&"?
Neil
Did my XSLT not work for you Neil? Take another look... check you are using the CDATA data - and disable-output-escaping on the value-of.
Cheers, Lee.
It did Lee - once I read the page Dan linked to and realised that "&" is the valid approach.
It was just throwing me a little when I clicked the link and saw the "&" in the address bar - I just assumed the browser would change this.
