  • Ivan 139 posts 302 karma points
    Feb 25, 2010 @ 13:04
    Ivan
    Help for filtering import from external data source
    Hi:
    I am importing entries from external data source and need to filter entries imported by ID number.
    During import process, system will check if current entry ID is contained in an array of skippable numbers and, in that case, entry will be ignored.
    Is there anyaway i can do that in pure XSLT? I could use a C# function but i prefer not to.
    If you could send me an example explaining how to do array check you will make my day ;-)
    Ivan
  • Thomas Höhler 1237 posts 1709 karma points MVP
    Feb 25, 2010 @ 14:22
    Thomas Höhler
    You can use the contains function, I have used it to hide defined nodeTypes from the menu:
    <xsl:param name="nodeTypes">dtFeriCareer;dtFeriStiftungsCommunityStiftung;</xsl:param>
    <xsl:for-each select="... and contains($nodeTypes, concat(@nodeTypeAlias, ';'))">
    hth, Thomas
    Feb 25, 2010 @ 14:28
    Ivan
    You are the best Thomas ;-)
    Thanks a lot!
