  • Chris Gaskell 59 posts 142 karma points
    Feb 25, 2010 @ 15:00
    Chris Gaskell
    Some help wioth setting a subset of nodes into a variable
    Hey,
    I'm building an RSS Feed (well fixing it actually) and it has to work across different child doc types. The Child doc types all ahev the correct properties.
    So what mi trying to do is:
      <xsl:variable name="DataSource">
        <xsl:choose>
            <xsl:when test="$currentPage [@nodeTypeAlias = 'K-KnowledgeArticle']">
                <xsl:value-of select="$currentPage//node [@alias = 'K-KnowledgeArticle']"/>
            </xsl:when>
    <xsl:when text="...">
    etc
            <xsl:otherwise>
            </xsl:otherwise>
        </xsl:choose>
      </xsl:variable>
    Then:
    <xsl:for-each select="$DataSource">
          <xsl:sort select="@createDate" data-type="text" order="descending" />
          <xsl:if test="position() = 1">
    Is that possible?
    Thanks.
    Feb 25, 2010 @ 15:01
    Chris Gaskell
    Cripes, sorry for the typos...
    Feb 25, 2010 @ 15:03
    Chris Gaskell
    Sorry - should have added the error message on save:
    Error occured
    System.Xml.Xsl.XslTransformException:
    To use a result tree fragment in a path expression, first convert it to
    a node-set using the msxsl:node-set() function.
    at System.Xml.Xsl.Runtime.XsltConvert.EnsureNodeSet(IList`1 listItems) at pubDate(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    Feb 25, 2010 @ 15:07
    dandrayne
    Hows about using (it may be msxml:node-set, i can never remember).  If the below doesn't work post the copy-of output of your variable se I can see the structure
    <xsl:for-each select="msxsl:node-set($DataSource)">
    Feb 25, 2010 @ 15:16
    Chris Gaskell
    Got it, thanks Dan.
