  • Fabian 5 posts 23 karma points
    Mar 12, 2010 @ 17:16
    Fabian
    RenderMacroContent works / does not work..
    I have made a macro from a usercontrol. It shows a gridview, a button and a textbox (the latter two just for testing purposes). Now I call this macro with RenderMacroContent from an xslt. I know several of you stated the use of a .net-usercontrol in a macro being called from a xslt-macro is not possible, but is does work for all text, the button and the texbox in this ascx. Just not for the gridview. I do not need any functionality from the usercontrol, just the rendered output.
    Why is the gridview not shown when the other elements do show? Isn't the gridviews output not just a table?
    Thanks ahead!
    Fabian (Umbarco 4.0 / Asp 3.5)
