  • Rasmus Beuchert 14 posts 35 karma points
    Mar 20, 2010 @ 18:24
    Rasmus Beuchert
    Using custom datatype as macro parameter
    Hello
    I have made a new datatype using the dropdown list, hoping that I could use it as a macro parameter, but the list of parameter types seems to be static.
    Is there a way to use my own data types as a macro parameter?
    Rasmus
  • Frederik Vig 29 posts 61 karma points
    Mar 21, 2010 @ 11:41
    Frederik Vig
    Take a look at this post: http://www.richardsoeteman.net/2010/01/04/CreateACustomMacroParameterType.aspx
    Hope it helps.
    Frederik
    Mar 21, 2010 @ 13:58
    Rasmus Beuchert
    Perfect, that was the solution I was looking for.
    Thanks!
    Rasmus
  • suzyb 476 posts 934 karma points
    May 11, 2011 @ 16:11
    suzyb
    Major bump as I need some clarification on this.
    Is the custom data type (based on the dropdownlist) and the custom macro parameter shown in the blog post above different things.
    If so I assume I will then need to make sure the prevalues in the drop down list data type match those in the macro type.
    (I assume this still applies in v 4.7)
