  • Hamish 96 posts 154 karma points
    Mar 25, 2010 @ 06:32
    Hamish
    Why does value-of not work when inside a param or variable
    When I use:
    <xsl:variable name="list" select="$currentPage/node [string(data [@alias='umbracoNaviHide']) != '1']"/>
    It works fine... but when I try to do the following:
    <xsl:variable name="list">
         <xsl:choose>
            <xsl:when test="$currentPage/@nodeTypeAlias = 'Resource Listing'">
                <xsl:value-of select="$currentPage/node [string(data [@alias='umbracoNaviHide']) != '1']"/>
            </xsl:when>
            <xsl:otherwise>
            </xsl:otherwise>
         </xsl:choose>
    </xsl:variable>
    It breaks the xslt???
    Does any have any insights to this?
  • skiltz 501 posts 701 karma points
    Mar 25, 2010 @ 07:40
    skiltz
    Where is $currentPage declared? Maybe its gone out of scope??
    Mar 25, 2010 @ 08:35
    What kind of error message do you receive when trying to save the XSLT?
    And have you tried to see if the XSLT in fact works if you check the "Skip error testing" box?
  • Josh Reid 182 posts 258 karma points
    Mar 25, 2010 @ 08:44
    Josh Reid
    Hamish if you are finding that you get the error:
    'cannot convert result tree fragment to nodeset'
    Then try doing this with your variable when you need to use the list variable as for-each, etc:
    <xsl:for-each select="msxml:node-set($list)/node">
    While the nodeset remains intact and as a nodeset when you use inside the variable select, it becomes a result tree fragment when declared by value-of.
  • Chriztian Steinmeier 2800 posts 8790 karma points MVP 8x admin c-trib
    Mar 25, 2010 @ 09:00
    3
    Hi Hamish,
    Whenever you use value-of, the processor evaluates the result as a string, whereas select returns a nodeset. If you need to conditionally select the node(s) for a variable, you need to use copy-of instead of value-of, but then you're actually getting a "result tree frament" (as Josh mentions) - you can convert that to a nodeset using the msxml:node-set() function (remember to declare the msxml prefix - the standard XSLT templates does that automatically). So domething like this:
    <xsl:choose>
    <xsl:copy-of select="$currentPage/node[not(data[@alias = 'umbracoNaviHide'] = 1)]"/>
    </xsl:when>
    <xsl:otherwise>
    <xsl:copy-of select="...something else..."/>
            </xsl:otherwise>
    </xsl:choose> </xsl:variable> ... <!-- Use like this: --> <xsl:for-each select="msxml:node-set($list)/node">
    /Chriztian
    Mar 25, 2010 @ 09:30
    Josh Reid
    Well put Chriztian, I was probably a tad brief before...
    Mental note to write up more fully in the future ;)
    Mar 25, 2010 @ 22:08
    Hamish
    Thanks guys for your help and the insight of how value-of actually works..
    That info helped save my sanity...
