  • ruben 8 posts 28 karma points
    Apr 12, 2010 @ 12:05
    ruben
    sitemap nested if problem
    I'm stil a newbie at Umbraco and XSLT so please forgive me if this is a dumb question. I'm using the following code in my xslt to create a sitemap:
    <xsl:variable name="maxLevelForSitemap" select="4"/>
    <xsl:variable name="startLevel" select="2"/>
    <xsl:template match="/">
        <div id="sitemap">
            <xsl:call-template name="drawNodes">
                <xsl:with-param name="parent" select="$currentPage/ancestor-or-self::node [@level=1]"/>
            </xsl:call-template>
    </xsl:template>
    <xsl:template name="drawNodes">
        <xsl:param name="parent"/>
            <xsl:if test="umbraco.library:IsProtected($parent/@id, $parent/@path) = 0 or (umbraco.library:IsProtected($parent/@id, $parent/@path) = 1 and umbraco.library:IsLoggedOn() = 1)">
                <ul>
                <xsl:for-each select="$parent/node [string(./data [@alias='umbracoNaviHide']) != '1' and @level &lt;= $maxLevelForSitemap]">
                <li>
                        <xsl:if test="current()/@level > $startLevel ">
                                </a>
                        </xsl:if>
                        <xsl:if test="count(./node [string(./data [@alias='umbracoNaviHide']) != '1'
                                    and @level &lt;= $maxLevelForSitemap]) &gt; 0   ">
                                <xsl:with-param name="parent" select="."/>
                        </xsl:if>
                </li>
                    </xsl:for-each>
                </ul>
            </xsl:if>
    </xsl:template>
    The problem I have now is that the li is also shown for the root item which i obviously don't want.
    I tried to correct this by putting the <li> tag inside the if that tests the current level. but then I get the error that the <li> doesn't have a closing tag (quite normal of course). so I decided to put the <li>, </li> and the following if that tests for children inside the if that tests the level.
    like this:
        <li>
            </a>
            </xsl:if>
        </li>
    </xsl:if>
    but this doesn't work, which is quite a mystery to me.
    So I need a way to add logic around the <li> tag to decide wether or not to show it. which brings me back to the error I get when the closing </li> tag is not in the same if. I tried to show <li> like this &lt;li&gt; and this <![CDATA<li>]]>, which also did not result in the wanted result.
    I hope I explained the problem correctly. any help would be greatly apreciated.
  • Tommy Poulsen 514 posts 708 karma points
    Apr 12, 2010 @ 12:40
    Tommy Poulsen
    Hi Ruben
    How about moving your
    test to e.g. the for-each selection instead - then you only iterate the nodes below your start level.
    >Tommy
  • Seth Niemuth 275 posts 397 karma points
    Apr 12, 2010 @ 12:43
    Seth Niemuth
    I am not exactly sure what you want inside your topLevel and what you don't but you could use a choose statement:
                             <xsl:choose>
    <xsl:when test="current()/@level > $startLevel >
    <li>
                                                            </a>
                                            </xsl:if>
     </li>
    </xsl:when>
    <xsl:otherwise>
                                            </xsl:if>
    </xsl:otherwise>
    </xsl:choose>
                                    </xsl:for-each>
    Apr 12, 2010 @ 13:13
    ruben
    @tommy: that was idea too at first, but then it didn't display anything.
    @seth: that did the trick. I tried something similar with an if statement but now I see I made a logical mistake. Guess I'm not yet used to using the choose statement instead of the if statement :)
    thanks for the help and super fast response guys!
    Apr 12, 2010 @ 14:56
    Seth Niemuth
    ruben,
    the choose statement works like the classic if... else statement.
    you first declare the choose (<xsl:choose>)
    then if some condition is true we do that thing
    <xsl:when test="isConditionTrue">
    <!-- Some things to do -->
    </xsl:when>
    You can put in as many (<xsl:when test="isConditionTrue" >) as you want.
    Then, there is a catch all (<xsl:otherwise> <!-- Do this if nothing else is true --> </xsl:otherwise>), which will run if none of the other when conditional statments are true.
    Then, close your choose (</xsl:choose>).
    It is a very useful built in tool, which allows you to add a bit more logic to your XSLT.
    Apr 21, 2010 @ 15:54
    ruben
    Thanks for the explanation Seth. Guess I should really dive into some xslt and umbraco tutorials :)
