Hi for some reason this doesnt validate in the umbraco xslt editor in the backend:
<xsl:template match="/"> <xsl:for-each select="$currentPage/node [string(data [@alias='umbracoNaviHide']) != '1']"> <xsl:value-of disable-output-escaping="yes" select="umbraco.library:RenderTemplate(@id)"/> </xsl:for-each> </xsl:template> </xsl:stylesheet>
but this does
<xsl:template match="/"> <xsl:for-each select="$currentPage/node [string(data [@alias='umbracoNaviHide']) != '1']/node"> <xsl:value-of disable-output-escaping="yes" select="umbraco.library:RenderTemplate(@id)"/> </xsl:for-each> </xsl:template> </xsl:stylesheet>
The only difference is the lower example iteration ends with a '/node'.
I changed the xslt manually in VS and it works fine. But when I try to edit via the backend i get the yellow notifyer saying "xslt could not be saved"
Does anyone have an idea what could be causing this?
The solution in question runs on umbraco v 4.0.2.1
Cheers
Sune
Hi Sune, I'm not sure why you get different behavior in the 2 scenarios, but you may have to wrap the value-of ... RenderTemplate function in an if-statement testing that @id in not empty
<xsl:if test="@id != ''">...
Problem with umbraco.library:RenderTemplate?
<xsl:template match="/"> <xsl:for-each select="$currentPage/node [string(data [@alias='umbracoNaviHide']) != '1']"> <xsl:value-of disable-output-escaping="yes" select="umbraco.library:RenderTemplate(@id)"/> </xsl:for-each> </xsl:template> </xsl:stylesheet>but this does
<xsl:template match="/"> <xsl:for-each select="$currentPage/node [string(data [@alias='umbracoNaviHide']) != '1']/node"> <xsl:value-of disable-output-escaping="yes" select="umbraco.library:RenderTemplate(@id)"/> </xsl:for-each> </xsl:template> </xsl:stylesheet>The only difference is the lower example iteration ends with a '/node'.
Cheers
Sune
<xsl:if test="@id != ''">...is working on a reply...
