Hi all I have a usercontrol macro I'm trying to nest inside an xslt macro using the umbraco.library:RenderMacroContent unfortunately try as i might I can't get this to work.. just wondering if anyone had any suggestions?
Hi Tom, IIRC the problem with having an XSLT macro rendering out a UC macro is that the page lifecycle events in the UC macro won't fire - I'm guessing this is the issue you're having ?
Call usercontrol macro from xslt macro
<xsl:variable name="contactFormMacro" select="string(concat('<?UMBRACO_MACRO macroAlias="ContactForm" fileAttachmentsId="', data [@alias = 'currentFileAttachments'], '" ></?UMBRACO_MACRO>'))" />
<xsl:value-of select="umbraco.library:RenderMacroContent($contactFormMacro, number($currentPage/@id))" disable-output-escaping="yes"/>
Hi Hendy,
thanks so much for getting back to me.. yes that is true and nothing is being rendered.. alas!
I guess ill try and find a workaround
Hello Tom,
Now I have to implement the same scenario, call the usercontrol macro in xslt.
Did you find the workaround for that, if so, please let me know the solution.
Rao.
