  • AlexR 39 posts 61 karma points
    Apr 28, 2010 @ 12:40
    AlexR
    What diferense between xsl:variable with select and without select?
    Why the code
      <xsl:variable name="title" select="$node/data[@alias='nodeTitle']">
    </xsl:variable>
    returnt title
    but the code
      <xsl:variable name="title">
    <value-of select="$node/data[@alias='nodeTitle']" />
    </xsl:variable>
    return empty ?
    I need get $node/data[@alias='nodeTitle'] or $node/@nodeName and the code
    <xsl:choose>
    <xsl:when test="$node/data[@alias='nodeTitle']">
    </xsl:when>
    <xsl:otherwise>
    <xsl:value-of select="$node/@nodeName" />
    </xsl:otherwise>
    </xsl:choose>
    </xsl:variable>
    return empty.
    Apr 28, 2010 @ 12:48
    Lee Kelleher
    Hi Alex,
    With your second code snippet, you are missing the "xsl:" namespace prefix, so it doesn't work:
     <xsl:value-of select="$node/data[@alias='nodeTitle']" />
    Cheers, Lee.
    Apr 28, 2010 @ 13:14
    AlexR
    Yes! You are right.
    But why it is compiled whout any error?
    Masaraksh!
    Apr 28, 2010 @ 13:23
    Lee Kelleher
    The reason there is no error... is because, there is no error. The syntax is correct.  As far as the XSLT is concerned the tag you used <value-of ... /> is just arbitrary XML.  Errors will occur if you tried to use an incorrect XSLT tag, i.e. <xsl:whatever> because that isn't defined in the XSLT namespace.
    I'm guessing that you don't get any error since the element is actually being wellformed so the parser does not notice that it should in fact have been prefixed with a namespace.
  • Tobias Neugebauer 52 posts 93 karma points
    Apr 28, 2010 @ 13:24
    Tobias Neugebauer
    because this is totally valid xml (xslt) you need to prefix with xsl: that the xslt-processor knows what to do with it.
    Toby
    Once again beaten by Lee. Congrats on the MVP status! :-)
    Apr 28, 2010 @ 13:29
    Lee Kelleher
    @Jan: Thank you. Looking forward to finally meeting you at CG10!
