  • Gordon Saxby 1461 posts 1883 karma points
    May 08, 2010 @ 19:13
    Gordon Saxby
    Problem using an array
    after seeing this - http://our.umbraco.org/wiki/reference/xslt/snippets/date---add-'th,-st,-rd,-nd'-extension - I tried to adapt it to my specific use, but it's not working.
    I have the array as above
    <xsl:variable name="endings" select="umbraco.library:Split('st,nd,rd,th,th,th,th,th,th,th,th,th,th,th,th,th,th,th,th,th,st,nd,rd,th,th,th,th,th,th,th,st',',')"/>
    and then my code (just the bit to get the "th" etc) which is in a for-each loop
    <xsl:value-of select="$endings/value[number(./data [@alias = 'CalendarItemDay'])]/text()" />
    but nothing is returned. "CalendarItemDay" is a numeric datatype with values such as 3, 23, etc.
    This line displays the day value correctly
    <xsl:value-of select="./data [@alias = 'CalendarItemDay']"/>
    Any ideas?
  • Sebastiaan Janssen 5060 posts 15522 karma points MVP admin hq
    May 09, 2010 @ 12:12
    Sebastiaan Janssen
    Strange. Try sticking the CalendarItemDay in a variable first and see if it works like that.
    <xsl:variable name="dayNumber" select="number(./data [@alias = 'CalendarItemDay'])" />
    It might be that the conversion to a number fails at some point, so make sure to try and output the $dayNumber var during debugging as well.
    Another idea if to stick just a number in the value, like:
    <xsl:value-of select="$endings/value[3]/text()" />
    Just to make sure the error is not in the array.
    May 09, 2010 @ 18:53
    Gordon Saxby
    Very strange indeed! Putting the value of "CalendarItemDay" into a variable and using that variable to select the required array item worked!
    The strange thing is, I thought you couldn't reassign a value to a variable once it was declared!? The code is in a for-each loop.
    Anyway, it is working now, thank you.
    May 11, 2010 @ 10:58
    Sebastiaan Janssen
    It's not reassigned, after each loop the variable is destroyed and recreated. :-) Glad it's fixed!
