I have a master document type with an ultimate picker and a text field.
I need the values from the picker from the first node in any child nodes when not filled in the child nodes. I can't seem to get the values from the picker. does this work recursivly? If I use the same call on the textfield propery, I get the value from this recursively?
I tried the pagevalue approach and the xslt call approach with ancestor-or-self::node[position()=1]. this doesnt show anything. If i change [1] to last() I get the result from the first page, but then when I fill in the values in the child page, I only will get the ones from the first page.
The text field show it's value everytime correctly.
Yes, I have read that post, but I don't get a string with CSV's back .That's the strange thing.
I have read a post about related links and tried that code and it works... kinda...
I have this layout of pages:
home |____ Page 1 |___Page 1-1 home2 |____Page 1 etc.
In the home-page I have added values to the picker. When I open page 1 or page 1-1 I get the values from home.
If I add picker values to page 1 and open page 1-1 I get the values from the picker in page 1. Is this the normal behaviour? I thought I would get the values from the home?
That's the normal behavior. You're getting the first node that has the headerPhotos property(from the current node). Usually that's used to allow a default property to be set at a high level in the tree. Then you set the property at a lower level only if you need to override it. Should be the same thing as using recursive="true" on an item in a template.
Seems like last() is what you want - not sure why that's not working for you.
Ultimate Picker Recursive Values Not Working
Any ideas?
thanks
Hi Mike
I think you should read this great article by Lee Kelleher, which explains how to get values from the ultimate picker. http://blog.leekelleher.com/2009/09/08/umbraco-ultimate-picker-xslt-example/
I hope this helps.
home
|____ Page 1
|___Page 1-1
home2
|____Page 1
etc.
Here's the code:
[code]
<xsl:for-each select="$currentPage/ancestor-or-self::node [data[@alias='ultimatepickerfield'] != ''] [1] /data[@alias='ultimatepickerfield']">
<xsl:value-of select ="."/>
</xsl:for-each>
[/code]
thanks
Code again:
