Missing recursive bool parameter comes through as its advanced macro syntax
Hi, this is my first post. I used the IRC channel freenode#umbraco to some good effect on my last Umbraco project, but there's really not much activity at this point, so I've stopped in here :) I invite everyone over to the IRC channel if you're interested in semi-realtime Umbraco chat. My nick's nottwo.
Thanks! On to my current issue:
I have a macro called ListProducts that has a boolean parameter called AllBrands and I call it from a document masterpage with:
Either in that document or one of its ancestors is a checkbox field called AllBrands.
In my macro, I test the value of /macro/AllBrands and modify its behaviour. I've found that when the document or its ancestor has the AllBrands checkbox checked, the macro parameter comes in as '1'. If the AllBrands checkbox is not checked, /macro/AllBrands comes in as '[$AllBrands]', when I expected it to be either 0 or the empty string.
I've tried modifying the macro call to try to provide the empty string as a default if AllBrands is not checked, but /macro/AllBrands still holds the value of the unreplaced macro parameter string. In fact, giving a non-empty alternate replacement string also isn't
passed to my macro. I still get '[$AllBrands]' passed to my macro when
AllBrands is not checked anywhere in the node tree:
Is this the expected behaviour? I can test /macro/AllBrands against the value '[$AllBrands]' (and that's what I'm doing, for now), but this doesn't seem quite right. Any thoughts would be welcome.
I've seen this behaviour on a recent project as well, thougth it had something to do with my current umbraco setup, but now that you're experiencing the same issue, I'd definitely report this on Codeplex to get it solved. Can you do that please. Also make sure to include a repro path and enviroment specs so core team can repro and resolve this bug...
Don't forget to add a link to the codeplex issue so others can go and vote for it.
I've tried modifying the macro call to try to provide the empty string as a default if AllBrands is not checked, but /macro/AllBrands still holds the value of the unreplaced macro parameter string. In fact, giving a non-empty alternate replacement string also isn't passed to my macro. I still get '[$AllBrands]' passed to my macro when AllBrands is not checked anywhere in the node tree:
Thanks!
trannie
This is all running on:
Windows Server 2008
IIS 7
.NET 3.5
Umbraco 4.0.3
Trannie,
/Dirk
Hi Dirk,
I did open an issue on CodePlex, http://umbraco.codeplex.com/WorkItem/View.aspx?WorkItemId=27097 ; I'm not sure what a repro path is. Hopefully I included enough information.
I saw another issue that looks like it's the same issue: http://umbraco.codeplex.com/WorkItem/View.aspx?WorkItemId=26959
trannie
