  • Ranjith 11 posts 31 karma points
    May 25, 2010 @ 11:59
    Ranjith
    Error on Top Navigation
    Hi All,
    This is Ranjith..... When I install the Runway Top Navigation, I am getting the following error on the page.....  May I know how to clear this bug?? And I need the reason for this bug too......
    " Error parsing XSLT file: \xslt\RunwayTopNavigation.xslt "
    I know it might be so simple for the developers in the Forum....
    Thanks in Advance.....
  • Peter Gregory 408 posts 1614 karma points MVP 3x admin c-trib
    May 25, 2010 @ 12:11
    Peter Gregory
    What version of Umbraco are you running?   What that error is telling you is that there is a syntax error in the XSLT file.  Have you installed anything else other than the runway top navigation such as an XSLT Extension?
    peter
    May 25, 2010 @ 12:41
    Ranjith
    I am using Umbraco version4 Peter.....   I am learning to work with Umbraco4...... I have only installed Runway package and Runway Top Navigation, that's all...........
  • Bert 128 posts 251 karma points
    May 25, 2010 @ 13:54
    Bert
    you changed anything to the xslt? Installed it twice?
