Is there something wrong with this? I would expect the page to sort by the value given to them but they don't.
<xsl:for-each select="$currentPage/ancestor-or-self::node [@level=$level]/node [string(data [@alias='umbracoNaviHide']) != '1']"> <xsl:sort select="@pageSortOrder" order="ascending" data-type="number" /> <li> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="@nodeName"/> </a> </li> </xsl:for-each>
Hi Peter,
try changing
@pageSortOrder
to
@sortOrder
The reason in because there is no @pageSortOrder value but there is a @sortOrder
Tom
Just on a side note, if you are sorting by the @sortOrder ascending, you shouldn't actualy need the sort at all, as the nodes should already be presented in that order.
Matt
Sort order on property won't work
<xsl:for-each select="$currentPage/ancestor-or-self::node [@level=$level]/node [string(data [@alias='umbracoNaviHide']) != '1']"> <xsl:sort select="@pageSortOrder" order="ascending" data-type="number" /> <li> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="@nodeName"/> </a> </li> </xsl:for-each>Hi Peter,
try changing
@pageSortOrder
to
@sortOrder
Tom
Hi Peter,
Matt
