I'm using the topnavigation macro for my navigation, and i wan't to put class="active" on the link which you are currently looking at.
So if you are at information.aspx then in the navigation the information.aspx link shall have class="active" but the other links in the navigation shall not have class="active" - how to do that? I've been playing around with it and I can only get it to either all have class="active" or none...
<!--This sets the level that the nav starts at and tells us if we should recurse through child elements--> <xsl:variable name="startDepth" select="/macro/startingLevel" /> <xsl:variable name="recurse" select="/macro/recurse" /> <xsl:variable name="selectBranches" select="/macro/selectBranches"></xsl:variable> <xsl:variable name="maxMenuDepth" select="/macro/maxMenuDepth"></xsl:variable> <xsl:variable name="forceNode" select="/macro/forceNode"></xsl:variable> <xsl:variable name="walkChildren" select="/macro/expandChildren"></xsl:variable> <xsl:variable name="forceHome" select="/macro/forceHome"></xsl:variable> <xsl:variable name="subNav" select="/macro/subNav"></xsl:variable> <!--Alternate page title variable in here-->
<!--Styles for the navigation--> <xsl:variable name="ulBaseClass" select="/macro/ulBaseClass"></xsl:variable> <xsl:variable name="branchClass" select="/macro/branchClass"></xsl:variable> <xsl:variable name="selectedClass" select="/macro/selectedClass"></xsl:variable>
<!--Set the current node id i.e. the node we have looped to not the current page--> <xsl:variable name="currentNodeID" select="./@id" />
<!--Is the node a branch? i.e. are there children and is it in the colletion of ancestor nodes --> <xsl:variable name="isBranch"> <xsl:choose> <xsl:when test="$pseudoCurrentPage/ancestor-or-self::node[@id = $currentNodeID]/child::node">1</xsl:when> </xsl:choose> </xsl:variable>
<!--Is the node selected? i.e. is it the same as the currentPage node--> <xsl:variable name="isSelected"> <xsl:choose> <xsl:when test="$pseudoCurrentPage/@id = $currentNodeID">1</xsl:when> </xsl:choose> </xsl:variable>
Can't you use the stuff from the "Navigation prototype" XSLT?
<a href="{umbraco.library:NiceUrl(@id)}"> <xsl:if test="$currentPage/ancestor-or-self::node/@id = current()/@id"> <!-- we're under the item - you can do your own styling here --> <xsl:attribute name="style">font-weight: bold;</xsl:attribute> </xsl:if> <xsl:value-of select="@nodeName"/> </a>
Then instead of adding the style attribute just write <xsl:attribute name="class">active</xsl:attribute>
TopNavigation problem
hey,
i attached the xslt that i'm using for top navigation, that take care for the "active" page (look for the "selectedClass" variable).
Eran.
Hi Daniel
</xsl:if>
</a>
Here you go: (Just change "current" to whatever you'd like)
Thanks, it worked..
Doesn't really understand why my own doesn't, but nevermind - thanks for the help guys :)
please mark this question as resolved
