Problem when sync database from webform ASP.Net to Umbraco
I have one website is webform Asp.net 4.0 and SQL server 2012. Now I want to switch to using Umbraco but can not transfer the old data to data of Umbraco.
Please give me the solution!
Thanks!
Can you show what data do you have in old site ?
You can easy transfer data with few rows of code if you will understand which data and where to move it.
I have one website is webform Asp.net 4.0 and SQL server 2012. Now I want to switch to using Umbraco but can not transfer the old data to data of Umbraco. Please give me the solution! Thanks!
Hi Thanh,
Can you show what data do you have in old site ? You can easy transfer data with few rows of code if you will understand which data and where to move it.
