  • Dennis Adolfi 1082 posts 6450 karma points MVP 6x c-trib
    Apr 16, 2016 @ 07:32
    Dennis Adolfi
    Custom validation for prevalue fields
    Hello Umbracians. I have a problem.
    Im creating a custom propertyeditor with a few prevalue fields. One of them is a number field that i need to be required. I´ve managed to add the validation type "Required" and it works just fine (the editor cannot be saved without a number value) but i want to show my custom errormessage. What do i add to get this?
    This is my prevalue field:
            fields: [
                                label: "Max number",
                                description: "Max number.",
                                key: "maxNumber",
                                view: "number",
                                validation: [
                                    type: "Required",
                                    errorMessage: "Custom message", <-- Did not work
                                    errorMsg: "Custom message", <-- Did not work
                                    message: "Custom message", <-- Did not work
    All the above gives me this generic error message:
    Hope anyone can help!
    Apr 18, 2016 @ 07:37
    Dennis Adolfi
    Great thinking Dennis, posting a thread on a weekend.
    I keep forgetting that other people have lives..
  • Peter Bersani 14 posts 34 karma points
    Jun 04, 2018 @ 18:59
    Peter Bersani
    Ever figure this out? I am having the exact same problem.
    Jun 04, 2018 @ 20:36
    Hi Peter
    Could you perhaps share your current code on a Github gist for instance? it will make it a bit easier to understand the full context of your issue. I get that you need to be able to display a custom error message defined in the package.manifest but getting the full context will make it easier to test the code on a local instance of Umbraco and figure out if this might be a bug that needs to be addressed or if it's better and more desirable to make a workaround where you do the validation in the controller yourself by hooking into the notificationService for instance.
    Looking forward to hearing from you.
