  • Biagio Paruolo 1621 posts 1914 karma points c-trib
    Jun 29, 2016 @ 16:40
    Biagio Paruolo
    Dashboard.config: How to add <section> dinamically?
    How to add
    dinamically to dashboard.config file without to manually add section when install a plugin o a custom section?
    Dec 11, 2021 @ 10:35
    Marc Goodson
    Hi Biagio
    You want to look at the subject of 'Package Actions'
    These actions allows you to add instructions to your plugin so that when they are installed by the backoffice, they can insert into dashboards.config or trees.config the necessary settings to display your package.
    In V7, it's based on a configuration transform file https://our.umbraco.com/Documentation/Extending/Packages/Package-Actions/index-v7#add-dashboard-section
    In V8, the package actions can be written in code: https://our.umbraco.com/Documentation/Extending/Packages/Package-Actions/custom-package-actions
    regards
    Marc
    v8:
