I have installed the Merchello package on my Umbraco (Version 7).
As far as I know, there is Merchello on pack-end of the Umbraco site. How can I set up it to show the front end of Merchello with some sample products?
In order to have a front store for Merchello, Merchello package should be installed. We will install bazaar for Merchello to have a sample store for Merchello. Link to download bazaar:
How to establish front store for Merchello on Umbraco?
I have download Merchello package:
https://our.umbraco.org/projects/collaboration/merchello/
https://our.umbraco.org/projects/starter-kits/merchello-bazaar/
Hi Nguyen,
The Merchello guys have also create a new starter kit called FastTrack.
You can download it here: https://our.umbraco.org/FileDownload?id=16323
Hope this helps,
/Dennis
