  • Bo Jacobsen 610 posts 2409 karma points
    Sep 15, 2016 @ 20:36
    Bo Jacobsen
    dialogService open with umb-overlay-backdrop and on-outside-click closeOverLay
    Hello Everyone!
    Is there way to use dialogService.open and affect the element with class="umb-overlay-backdrop" and use on-outside-click="closeOverLay()"
    Its like when you open a treepicker or media picker. Then umb-overlay-backdrop gets displayed and its like fadeding out the content and make it unselectable. And when you click it the dialog modal disappear and the umb-overlay-backdro get set to display: none.
    Using umbraco 7.4.3
    //This is what we are talking about ;)
    dialogService.open({
        template: "/App_Plugins/MyPlugin/Dialog.html",
        dialogData: $scope.model.value,
        callback: function (value) {
            if (value != null && value != "") {
                $scope.model.value = value
  • Michaël Vanbrabandt 863 posts 3348 karma points c-trib
    Sep 16, 2016 @ 06:48
    Michaël Vanbrabandt
    Hi Bo,
    can you show us some printscreens of the issue because now its not fully clear.
    /Michaël
    Sep 16, 2016 @ 08:18
    Bo Jacobsen
    I will try ;)
    The backdrop looks like this when not displayed. enter image description here
    Then i use the treepicker
    The treepicker enter image description here
    Then the backdrop gets displayed. enter image description here
    I hope it makes sense ;)
    Dec 07, 2016 @ 07:42
    Bo Jacobsen
    I found out how. I have to use the
    <umb-overlay
            ng-if="vm.overlay.show"
            model="vm.overlay"
            view="vm.overlay.view"
            position="right">
        </umb-overlay>
    https://our.umbraco.org/apidocs/ui/#/api/umbraco.directives.directive:umbOverlay
