  • Nguyen Dung Tri 106 posts 606 karma points
    Oct 04, 2016 @ 10:16
    Nguyen Dung Tri
    How to create a connection string which points to Azure Active Directory in Web.Config?
    Hello Dan Lister,
    I have use your "Active Directory Providers" on my project. When I go to the line of "create connection string which points to Azure Active Directory", I don't know how to create a connection string myself.
    Here are the information I got from Azure Active Directory:
    ClientId: a92a056f-????-????-????-3a86545656e2
    Domain: somedomain.onmicrosoft.com
    My account to log into portal.azure.com:
    Username: [email protected]
    Pass: xxxxxxxxx
    What should I put in connectionUsername, connectionPassword, and connectionstring?
    Example:
    <connectionStrings>
        <add name="MyMembershipConnectionString" connectionString="LDAP://somedomain.onmicrosoft.com/[email protected],OU=somedomain,DC=somedomain,DC=onmicrosoft,DC=com" />
      </connectionStrings>
    <add name="MyMembersMembershipProvider"
               type="RB.ActiveDirectoryProviders.ActiveDirectoryUmbracoMembersMembershipProvider, RB.ActiveDirectoryProviders"
               connectionStringName="MyMembershipConnectionString"
               connectionUsername="[email protected]"
               connectionPassword="xxxxxxxx"
               attributeMapUsername="sAMAccountName"
               defaultMemberType="MemberType" />
    When I run my website, it generate an error: Parser Error Message: Unable to establish secure connection with the server
    So that my sample connection string is not correct. Do you have any suggestion?
    Regards, Dung Tri
  • cronywalls 2 posts 72 karma points
    Mar 15, 2019 @ 06:10
    cronywalls
    You can encrypt the connectionstring section of a web.config file by using aspnetregiis.exe command line tool, so it is never stored as plain text. This file is located in the %systemroot%\Microsoft.NET\Framework\versionNumber folder and you can use with -pef option. Consider you have an application named as MyWebApp. You can encrypt the connectionStrings section of the Web.config file by using aspnetregiis.exe as follows :
    aspnet_regiis.exe -pef "connectionStrings" "/MyWebApp"
