  • Aki 43 posts 214 karma points
    Feb 09, 2017 @ 12:28
    Aki
    Keep Focus Grid Element
    im working on a plugin
    it uses a html file that includes a controller
    using a list $scope.control.ElementList adding a removing element works fine..
    and the Ng-repeat uses this ...
    in code i have a
        $scope.Delete = function () {
             $scope.control.ElementList.splice(index, 1);
    now after deleting a element the focus on the Grid element is lost ...
    How do i keep it in focus ??
  • Ronak Panchal 71 posts 230 karma points
    Feb 09, 2017 @ 14:31
    Ronak Panchal
    Hello Aki,
    In .js File you can put that remove function
    $scope.Delete = function ($index) {
             $scope.control.ElementList.splice($index, 1);
    In html File i mean in Ng-repeat
    you can pass $index
    controllerName.Delete ($index)
    Hope this will help,
    Ronak Panchal.
    Feb 15, 2017 @ 08:05
    Aki
    yes your right and i already do this.. i need to keep the focus on the grid element i just created.. after i use the save on the page...
  • Joe Craddock 1 post 71 karma points
    Jun 11, 2018 @ 22:23
    Joe Craddock
    Did you ever resolve this? Running into the same issue.
