Hook/Intercept Angular backend Menus and Tree Events
Hi folks!
In short:
I need to trigger a javascript snippet in the backoffice when the user switches to editing a page. So users press edit home -> run snippet.
I'm trying to find a way to hook into any of the Umbraco Angular events for the menus. I have currently made a ActionMenuItem where the snippet runs when the admin presses the button. However I need events for when a user for example leaves the content tab to settings.
Just wanted to share what the solution ended up to.
Challenge 1: Want to hook on events so I know if the user enter the editor mode or left it
Solution: Listen on the event $routeChangeSucess
// Try to find an event as late as possible so angular has been loaded
$(window).load(function () {
var $scope = angular.element('body').scope(); // Get scope from body
if ($scope) {
$scope.$on('$routeChangeSuccess', function(e, next, current) { });
The callback from the event "next" contains which tree you're on, which page id you're on etc.
Challenge 2: Listen on events for when user press the save and publish
Solution: From what I could find, the event emits from the controller Umbraco.Editors.Content.EditController.
// Method for the routeChangeSuccess event
on$routeChangeSuccess: function (e, next, current) {
// Only listen when user works on the content tree
if (next.params.tree === 'content') {
// The controller does not exist until after the route change
// Wait one js tick to hook on the publish button.
setTimeout(function () {
var uEditController = angular.element($("body div [ng-controller='Umbraco.Editors.Content.EditController']"));
if (uEditController.length < 1) {
return;
var $scope = uEditController.scope();
// Hook on save and publish event
$scope.$on('formSubmitted', function (form) {
// Do stuff
}, 0);
Hi folks!
In short: I need to trigger a javascript snippet in the backoffice when the user switches to editing a page. So users press edit home -> run snippet.
