  • Mikael Ekström 14 posts 114 karma points
    Apr 22, 2017 @ 15:22
    Mikael Ekström
    Is there a easy way to add a project to the code instead of in the backoffice?
    I found a really nice package/project that I would like to use with my new umbraco installation but I would like to add it to the source code of the project instead of in the backoffice. Is there a easy way to do this?
    Kind regards, Mikael
  • Dennis Adolfi 1082 posts 6450 karma points MVP 6x c-trib
    Apr 23, 2017 @ 09:28
    Dennis Adolfi
    Hi Mikael. Maybe I've completely misunderstood your question but here goes:
    Do you mean that you would like to be able to install the package from within say Visual Studio instead of logging in to the back office and installing the package from the package repository?
    A lot (not all of them) of packages for Umbraco have nuget installs and now they are also displayed nicely on the our package page. Se example: https://our.umbraco.org/projects/backoffice-extensions/skybrudimagepicker/
    If they don't have a nuget install then I guess you need to install it from the back office.
    Again, my apologies if I totally misunderstood your question.
    Hope you are having a great weekend!
    All the best / Dennis
