  • Bernard Moes 13 posts 134 karma points
    Jul 28, 2017 @ 10:48
    Bernard Moes
    Default package language
    I am trying to add localization support to my package and want to keep all my language files in a single place. One thing that bothers me is that there appears to be no such thing as a default.xml to catch all unsupported languages. Right now I have to provide the defaults inside my html code. Example:
    <localize key="general_label">Default value</localize>
    Is there any workaround to solve this issue?
    EDIT: the default value doesn't work this way either. It just returns general_label when I set my language to an unsupported language. How do I supply a default value?
    Jul 28, 2017 @ 13:49
    Bernard Moes
    At least I fixed the inline default. The directive below only replaces the inline default "Default value" when a translation is available:
    function CustomLocalize(localizationService) {
        return {
            restrict: 'E',
            scope: {
                key: '@'
            replace: true,
           link: function (scope, element, attrs) {
                var key = scope.key;
                localizationService.localize(key).then(function (value) {
                    var re = new RegExp("\^\\\[\\w\+\\\]\$");
                    if (!re.test(value)) {
                        element.html(value);
    Still I didn't find a way to centralize defaults. If anyone could help me here I'd appreciate it.
