  • Sotiris Mastrandrikos 6 posts 26 karma points
    Dec 08, 2017 @ 09:28
    Issues with ng-grid
    I have created a property editor that displays all child nodes using ng-grid.
    the package.manifest:
    {  propertyEditors: [
            alias: "ContentsGrid",
            icon: "icon-code",
            group: "Rich Content",
            editor: {
                view: "~/App_Plugins/ContentsGrid/ContentsGrid.html"
    javascript: [
        '~/App_Plugins/ContentsGrid/ng-grid.min.js',
        '~/App_Plugins/ContentsGrid/ContentsGrid.controller.js'
    css: [
        '~/App_Plugins/ContentsGrid/ng-grid.min.css'
    the controller:
    var gridApp = angular.module('umbraco'); gridApp.requires.push('ngGrid'); gridApp.controller("ContentsGridController", function ($scope, editorState, contentResource) {
    $scope.currId = editorState.current.id;
    contentResource.getChildren(editorState.current.id).then(function (data) {
        $scope.childNodes = data.items;
        //console.log(JSON.stringify($scope.childNodes));
    $scope.columnDefs = [
       { field: 'id', displayName: 'ID' },
       { field: 'name', displayName: 'Name' }
    $scope.myOptions = {
        columnDefs: 'columnDefs',
        data: 'childNodes'
    the html:
    <div ng-controller="ContentsGridController">
    <div ng-grid="myOptions"></div>
    Actually it works without issues when application starts and the first node is clicked. However, after choosing another node console returns an error:
    TypeError: n.swap is not a function at Object.o.getRealWidth (AppPlugins/ContentsGrid/ng-grid.min.js?cdv=1:1) at Object.o.UpdateGridLayout (AppPlugins/ContentsGrid/ng-grid.min.js?cdv=1:1) at Object.o.AssignGridContainers (AppPlugins/ContentsGrid/ng-grid.min.js?cdv=1:1) at AppPlugins/ContentsGrid/ng-grid.min.js?cdv=1:2 at i (umbraco/lib/angular/1.1.5/angular.min.js?cdv=1:79) at umbraco/lib/angular/1.1.5/angular.min.js?cdv=1:80 at Object.$eval (umbraco/lib/angular/1.1.5/angular.min.js?cdv=1:92) at Object.$digest (umbraco/lib/angular/1.1.5/angular.min.js?cdv=1:90) at Object.$apply (umbraco/lib/angular/1.1.5/angular.min.js?cdv=1:92) at j (umbraco/lib/angular/1.1.5/angular.min.js?cdv=1:101) (anonymous) @ umbraco/lib/angular/1.1.5/angular.min.js?cdv=1:63 umbraco/lib/angular/1.1.5/angular.min.js?cdv=1:63 TypeError: Cannot read property 'assignEvents' of undefined at Object.fn (App_Plugins/ContentsGrid/ng-grid.min.js?cdv=1:2) at Object.$digest (umbraco/lib/angular/1.1.5/angular.min.js?cdv=1:90) at Object.$apply (umbraco/lib/angular/1.1.5/angular.min.js?cdv=1:92) at j (umbraco/lib/angular/1.1.5/angular.min.js?cdv=1:101) at r (umbraco/lib/angular/1.1.5/angular.min.js?cdv=1:104) at XMLHttpRequest.w.onreadystatechange (umbraco/lib/angular/1.1.5/angular.min.js?cdv=1:106)
    any help would be appreciated!
    Thanks in advance
  • Alex Skrypnyk 6179 posts 24240 karma points MVP 8x admin c-trib
    Dec 08, 2017 @ 14:24
    Alex Skrypnyk
    Hi Sotiris
    It looks like 'ng-grid' library isn't compatible with Umbraco backend, can you check that ng-grid is working with angular version that is in Umbraco backend?
    Alex
