I'm rendering a content picker into a package, which is all working nicely, using the umb-property-editor directive and providing a data model (alias, view and a simple config).
It's rendering nicely, I can select a node or two, and save it off to my settings store. Issue is that on reloading the view, the content picker does not update with the selected values - these are fetched from the DB, and when the promise resolves, I update the picker model with the new value.
That should (I thought) trigger the watch in the content picker controller and update the render model. The watch never fires on receipt of the data (it does on the initial page load, when the value is empty).
Has anyone done similar?
// other controller code
vm.excludeNodesModel = {
view: 'contentpicker',
alias: 'excludeNodesPicker',
config: {
multiPicker: '1'
$q.all(promises)
.then(function (resp) {
// code removed for brevity
// this value is a comma-delimited list of node ids, so is a valid value for the contentpicker
if (vm.settings.excludeNodes) {
// thought this would trigger the watch on the contentpicker value...
vm.excludeNodesModel.value = vm.settings.excludeNodes;
Found a solution - it's a bit messy but does the job.
Basically needed to take the data returned from the server, access the directive scope, then pump my data in via the add() function. It means fetching each content item, so a bit of overhead, but in my case there would only ever be a handful of ids at most, so not a huge deal
Using contentpicker in a package - model updates not reflected in the view
Hi all
Example of the solution is here -> https://github.com/nathanwoulfe/Plumber/blob/fde77520d0dd8e1e81e39fa4505b513b04d4fe05/Workflow/App_Plugins/Workflow/Backoffice/controllers/workflow.settings.controller.js#L23-L39
