  • Rabea_M 26 posts 140 karma points
    Jan 31, 2018 @ 12:32
    Rabea_M
    How to add a field to property settings
    Is it possible to add a custom field in property setting when our package is installed?
    Example
  • Kevin Jump 2348 posts 14896 karma points MVP 8x c-trib
    Feb 02, 2018 @ 10:08
    Kevin Jump
    Its not possible to add fields to the property settings dialog, but you can add fields to the property editor one. (which appears once you have selected an editor in add editor)
    the property settings are generic so it doesn't know what type of property you , want until you have picked an editor. but once you have done that then you can customise away.
    the property editor documentation is probably a good place to start. sepecifically you should looking at the prevalues configuration section
    Feb 02, 2018 @ 10:19
    Rabea_M
    Thanku for response kevin, I will try this approach
