  • Michaël Vanbrabandt 863 posts 3347 karma points c-trib
    Feb 06, 2018 @ 15:41
    Michaël Vanbrabandt
    Fire package controller function after clicking custom menu item
    Hi all,
    I have a BootStrapper class which adds a new menu item on the members menulist.
    I was wondering if its possible to fire a function inside my controller after hitting this menu item, or do we first need to show a dialog which then calls the controller function after hitting another button inside the dialog?
    public class PackageApplicationEventHandler : ApplicationEventHandler
        protected override void ApplicationStarted(
            UmbracoApplicationBase umbracoApplication,
            ApplicationContext applicationContext)
            TreeControllerBase.MenuRendering += Package_MenuRendering;
        private void Package_MenuRendering(TreeControllerBase sender, MenuRenderingEventArgs e)
            // If not rendering menu for the document types, return
            if (sender.TreeAlias != "member") return;
            var menuItem = new Umbraco.Web.Models.Trees.MenuItem("package", "Package Item");
            menuItem.Icon = "client";
            // Append someting to fire controller function inside
            // my App_Plugins/Package folder after hitting this menu item
            menuItem.SeperatorBefore = true;
            e.Menu.Items.Insert(e.Menu.Items.Count, menuItem);
    /Michaël
  • Dave Woestenborghs 3494 posts 12077 karma points MVP 7x admin c-trib
    Feb 06, 2018 @ 16:09
    Dave Woestenborghs
    Hi Michaël,
    I don't think this is possible. But I think you can still execute javascript from the menu. There is a ExecuteLegacyJs function on the menu item : https://github.com/umbraco/Umbraco-CMS/blob/5397f2c53acbdeb0805e1fe39fda938f571d295a/src/Umbraco.Web/Models/Trees/MenuItem.cs#L125
    Dave
    Feb 06, 2018 @ 17:17
    Michaël Vanbrabandt
    Hi Dave,
    thanks for the intel, I will then launch a new view to do the task.
    /Michaël
