  • Rotem Orbach 121 posts 607 karma points
    Aug 29, 2018 @ 13:08
    Rotem Orbach
    Lucene Search Engine results Hebrew
    Hi, I have implemented Lucene Search Engine results in my website, and it works flawlessly, except one distinct issue: When I try to search a Hebrew term that has double quotation marks in it, I get no results. For example: דפ"ר
    this word should return results, but it doesn't.
    Note: wild card works: דפ*
    Any thoughts?
    thanks, Rotem
  • Yakov Lebski 594 posts 2350 karma points
    Sep 10, 2018 @ 16:33
    Yakov Lebski
    You can try to use escape function - please see Lucene documentation https://lucene.apache.org/core/294/queryparsersyntax.html
    Sep 11, 2018 @ 08:43
    Ismail Mayat
    Rotem,
    Are you using hebrew analyser? See https://our.umbraco.com/packages/developer-tools/hebrew-search/ this may get round the problem. Ideally when doing multilingual you should use the language specific analyser if available.
    Regards
    Ismail
    Sep 13, 2018 @ 08:31
    Yakov Lebski
    just note that HebMorph is not free for commercial use
    from HebMorph website:
    If you are developing a commercial application, please contact us to discuss a commercial license. This helps us support development of future versions that make Hebrew search even better. Paid licenses are bundled with a proprietary dictionary, which replaces the AGPL3'd hspell used by the open-source version, as well as integration support.
    Sep 13, 2018 @ 09:02
    Ismail Mayat
    ah did not know that good spot.
    Sep 13, 2018 @ 08:34
    Rotem Orbach
    Thank you for the answers. I tried https://our.umbraco.com/packages/developer-tools/hebrew-search/
    and it does not solve the issue :(
    also, when I debug the search I can clearly see that the word is already escaped (דפ\"ר) Meaning: I can see the slash being added to the string, but still, no value is being returned.
    any other thoughts? :)
    thanks
    Ismail Mayat
    Rotem,
    I would reach out to itamar https://twitter.com/synhershko he ported lucene to lucene.net and put together HebMorph also he is native hebrew speaker.
    Regards
    Ismail
    Sep 20, 2018 @ 12:16
    Rotem Orbach
    Thanks, I marked your answer as solution, but unfortunately, Itamar did not replay, so I guess i'll have to face this one myself.
