We have the Dialogue plugin installed and have had some spam come through. This obviously means that we need to get rid of it.
Instead of me deleting it out of the database I've enabled the moderator settings (to empower our client to delete posts/topics themselves). The delete worked fine when I tested 2 or 3 deletes.. but now when trying to delete it causes our site to break (and does not necessarily delete the topic/post).
It seems like a memory leak (once the 'delete' button is pressed, I can see the memory usage climbing from 700mb to about 4gb). Once it has hit the 4gb mark, the site cannot be accessed anymore until I reset the app pool.
I'm not sure how to get in touch with the creator? Any ideas? Anyone else had this issue, hopefully with a fix?
Umbraco Dialogue: Breaks site when deleting topic/post (possible memory leak)
Hello
Kind regards, H
Hi Hannes,
Is it this package you are using? https://our.umbraco.com/packages/collaboration/dialogue/
If so, it might be worth raising an issue on the issue tracker for it: https://github.com/YodasMyDad/Dialogue/issues
It would be worth providing as many steps to re-produce the issue as possible to help them with their investigation :-)
Nik
