  • Tiago Mendes 5 posts 75 karma points
    Mar 18, 2019 @ 10:03
    Tiago Mendes
    Formulate Email Body Template
    I'm using the formulate to create my dynamic forms, but i dont know how to change the email body message.
    For example: I want to put labels on bold, change the payload labels or add some information on it.
    Can you help?
  • AddWeb Solution Pvt. Ltd 109 posts 354 karma points
    Mar 27, 2019 @ 06:56
    Hi Tiago Mendes,
    An approach that we have sometimes used at my work is to invent our own template tags.
    So in Umbraco you can setup a section for e-mail receipts and then have a receipt document type where you can allow the editor to customize the receipt.
    So you can give them a rich text editor and then invent some template tags like ##NAME##,##PASSWORD## and ##EMAIL## so the editors can write something like
    Hi ##NAME##
    Your password is ##PASSWORD## and we sent it to you on ##EMAIL##
    Then you can do a replace for the "template tags" when you're rendering/sending.
    You can refer below Github code link its may be help for you
    http://www.netaddicts.be/umbraco/a-developers-take-on-sending-emails-in-umbraco/.
    The post uses an outdate version on ActionMailer but the idea is the same.
    Hope this makes sense.
  • Nicholas Westby 2045 posts 7034 karma points c-trib
    Nov 29, 2020 @ 18:27
    Nicholas Westby
    Bit of a late response, but Formulate Pro supports that: https://www.formulate.rocks/pro/
    It is not something you can easily do out of the box with Formulate. Although, you could create a custom form submission handler if you want to avoid paying for Formulate Pro.
    BTW, the better place to ask these sorts of questions would be the Formulate forum: https://our.umbraco.com/packages/backoffice-extensions/formulate/formulate-questions/
